Which microcontroller to use and how?
Guest #5352350
• ▲ useful
▼ not useful
Hey Everyone.
i am a newbie in the microcontroller world. i am designing a circuit
which control battery cells simulation cells. So basically the goal is
to produce a voltage between 0 and 5 Volt. i will do this with a DAC
giving its output to a linear voltage regulator. and i would like also
to measure the current between the supply and the Linear voltage
regulator with a current monitor chip highside lowside which has also
I2C.
I wanna automate all of this process when i give different output values
from my DAC into the circuit. So My DAC ( MAX517 ) has I2C and my
Monitor Chip for the measuring ( INA226 ) has also I2C.
The question is i really have no clue about microcontrollers but what i
know is before choosing one i have to see the resoultion of my DAC which
is 16 Bit so i need atleast a microcontroller with 16 Bits and i also
need to check what kind of Interfaces i need. I think i need I2C and
maybe SP1 FOR LCD later? or Usb? and i need many digital inputs outputs.
the quesiton is now. Can someone briefly explain for me, which
microcontroller i need to control my DAC517 and which software i have to
write? which tools or softwares do i need?
I would really be glad for any help
Thanks
Regards,
Fadi
Guest #5352391
• ▲ useful
▼ not useful
You do not need a 16bit Microcontroller to process 16bit data. Every
8bit controller is capable to handle up to 64bit data without no
overhead from the programmers pint of view. And with some overhead it
can process any data that fit into the RAM.
Of courde, a native 64bit controller would process 64bit data faster.
But that's obviously not improtant for your project.
The interfaces are more interesting. If you find one that contains all
required interfaces then you have a nice single-chip solution. As more
chips you need as more error you may do.
Almost all microcontrollers are primarily programmed in C.
AVR microcontrollers (e.g. ATmega328P or ATmega32U4) are easy to learn
and there are lots of informations online. If you want something larger
then I would recommend any ARM based microcontroller, for example the
STM32F103 series which is available in different sizes).
Regarding your current monitor: If you measre the current between power
supply and voltage regulator then you measure the current consumption of
the voltage regulator + the load. So it would be more preciseto measure
the current at the output. Many voltage regulators have a separate
feedback pin which you can use to overcome the voltage loss at the
current sensor (shunt).
Guest #5352425
• ▲ useful
▼ not useful
It depends on your skills. It seems that you are not familiar with
microcontrollers, so start with Arduino Nano modules (ATmega328P). You
can program them with and without Arduino software. They are cheap, well
documented and have a very easy to use USB interface.
Guest #5352733
• ▲ useful
▼ not useful
Just for the case that the Arduino Nano has not enough I/O pins: The
ATmega2560 has much more of them and is also avaiable as a module with
USB connector.
But I would first check the smaller microcontroller, It's much more
handy. The programming model is the same on both.
Guest #5353066
• ▲ useful
▼ not useful
Fadi Safadi wrote:
> Can someone briefly explain for me, which microcontroller i need to
> control my DAC517
Industry would say: the cheapest that can do the job.
> and which software i have to write?
Seems to be a simple control program  not very fast not very complex so
even an ATmega8 can do the job. But of course you may have missed to
describe the bog hog part of it.
Use an Arduino. Simple Software and programmable over USB.
Not the cheapest but low tco.
