vivado w/o real board
Moderator (Company: Titel) #5344231
Elico C. wrote:
> Is it possible to do a design on VIVDO and simulate it without
>  connecting to it a real physical board just using some text file
Not only that it's possible, that's the usual way:
write a hardware description and write a testbench and then simulate the
first with (or better against) the second.
OP (Company: WS) #5344564
Hi
Is it possible to do with VIVADO virtual synthesis of some design
 without connecting a real board,
 just by saving the design to some text file and indicating the name of
the virtual board so that we will see the "would be " results that we
will
receive with that kind of board and "would be " FPGA chip in case we
will use such real board ?
Thanks
Elico
Moderator (Company: Titel) #5345123
Elico C. wrote:
> and indicating the name of the virtual board
What "virtual board"?
You do not need any kind of board to synthesize a design...
I urge you to get clear about the processing steps in the FPGA design
toolchain! When you don't know your toolchain then you don't know what
tool to use for what job. Finally you end by using a hammer to drive in
a screw.
To check out the size of design simply synthesize it not for a specific
FPGA, but for a complete family.
Or select the biggest FPGA in a family and synthesize the design for
that. Then you can see the resource needs of that design.
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
