ARM Cortex M7 64 bits floating point
Guest #5343471
Charles G. wrote:
> Does the GCC compiler support the ARM Cortex M7 64 bits floating point?
> If so what are the switches an where can I find the documentation.
There is no "ARM Cortex M7 64 bits floating point".
There are only ARM Cortex M7 with ARM FPv4 (for example some STM32F7
Devices) and ARM Cortex M7 with ARM FPv5 (for example some STM32F7 or
STM32H7 devices) extension.
For Options of gcc look at gcc docs, of course:
https://gcc.gnu.org/onlinedocs/gcc/ARM-Options.html
Look for armv7e-m, fpv5.
OP (Company: Fox Thermal Instruments) #5343915
I was under the impression that the ARM Cortex M7 support 32 and 64 bits
hardware floating point. We are having a product that does 32 bit
floating point using a different processor and ran into an accuracy
issue when trying to compute a 15 order polynomial. I am looking at a
new processor that can do either using a hardware or library that
support doing certain operation using 64 bits floating point. Any idea?
I did looked thru the provided link and I am still confused.
Thanks,
Charles
Guest #5345691
Check this:
https://en.wikipedia.org/wiki/Horner%27s_method
This may help with accuracy issues in polynomials. Cranking up from 32
to 64 bit is no cure in most of the cases. Been there, done that.
Cheers
Detlef
Guest #5346821
> This may be the only M7 with 64 bits:
> https://www.microchip.com/design-centers/32-bit/sam-32-bit-mcus/sam-s-mcus
No the STM32H7 Series also have the FPv5 extension for double precision
and is faster than the Atmel.
http://www.st.com/en/microcontrollers/stm32h7-series.html?querycriteria=productId=SS1951
In the slower STM32F7 Series - which is slower - there are also some
double precision devices.
http://www.st.com/en/microcontrollers/stm32f7-series.html?querycriteria=productId=SS1858
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
