Hello, I'm starting learning fpgas. I would like to connect my raspberry to my Altea Cyclone IV development board using jtag interface. I have found an example C code that uses the parallel port in http://www.fpga4fun.com/JTAG.html (file source code in http://www.fpga4fun.com/files/JTAG.zip). Do you have any example of C source code using jtag integration but through USB cable? Does it make sense? Is it the correct approach? Thanks for your help. Regards, hj
Hj 2. wrote: > using jtag integration but through USB cable? What USB cable? > I would like to connect my raspberry to my Altea Cyclone IV development > board using jtag interface. Why? To configure the FPGA? Or to communicate with a design implemented on the FPGA? > Does it make sense? Is it the correct approach? To achieve what?
Hi, Thanks a lot for your reply. I admit I need to learn more about this... >> using jtag integration but through USB cable? > What USB cable? Altera USB blaster cable > >> I would like to connect my raspberry to my Altea Cyclone IV development >> board using jtag interface. > Why? To configure the FPGA? Or to communicate with a design implemented > on the FPGA? To communicate with a design implemented on the FPGA > >> Does it make sense? Is it the correct approach? > To achieve what? I want to have a C program in my raspberry that interacting with this software I can send different orders to the FPGA board (turn leds, advance counter...)
Hj 2. wrote: > To communicate with a design implemented on the FPGA Then implement a simple serial interface and use that for communication. That's an interface easy to understand and easy to debug eg by using a terminal software on a PC instead of the RPi. And better: you can define the commands as you need them.
You mean for example something like this, using RS-232 serial interface? http://www.fpga4fun.com/SerialInterface.html My rasp does not have RS-232 connector, maybe I could use some kind of port or accesory... Could you point me to some interesting resources to understand active serial interface, passive serial interface, JTAG...? Differences? Advantages? Limitations? When to use what? Really thanks a lot.
