Hardware Target shutdown problem in nexys 4 ddr
OP #5324549
• ▲ useful
▼ not useful
Hello,
I am working on Nexys 4 ddr FPGA board.I have done
synthesis,implementation and bitsream generation succesfully but when I
programmed the bit file into the fpga board,the output is showing
results for n=5,20,60,80,100 bits and  above 100 bits the hardware
server automatically gets disconnect and the below error occurs.
ERROR: [Labtoolstcl 44-513] HW Target shutdown. Closing target:
localhost:3121/xilinx_tcf/Digilent/210292743548A
please provide any solution to how to fix the above problem
OP #5324992
• ▲ useful
▼ not useful
> And please report the 7 errors and 266 warnings. This must be
> utterly
> wrong so the Hardwaremanager fault might just be a symptom of many other
> errors.
There are no such errors and warnings after implementation ,it may be
due to previous files I have implemented design again and the problem i
am facing is of hardware server gets shutdown.The screenshot of my
problem is attached and also I have attached verilog code
OP #5325706
• ▲ useful
▼ not useful
> Well, there is no constraints file where the FPGA IOs are mapped
> to the
> signal names. Please provide the complete project. Without constraints
> there is no way to build the bitstream.
I have attached the xdc file of nexys 4 ddr. In constraint file,I have
uncommented only this line
set_property -dict { PACKAGE_PIN E3    IOSTANDARD LVCMOS33 } [get_ports
{ clk }];
because I am using virtual input output(VIOs) for generating bit file.
OP #5327584
• ▲ useful
▼ not useful
After Implementation I am getting this warning, what does it mean?
[Power 33-332] Found switching activity that implies high-fanout reset
nets being asserted for excessive periods of time which may result in
inaccurate power analysis.
Resolution: To review and fix problems, please run Power Constraints
Advisor in the GUI from Tools > Power Constraints Advisor or run
report_power with the -advisory option to generate a text report.
It may be possible because of this hardware server gets shutdown
automatically and not displaying any output.
For smaller number of bits,this warning is not there that's why it is
working
If anybody knows how to fix this problem then please provide any
suggestions
  • [vhdl]VHDL-Code[/vhdl]
