4-bit counter simulation problem
Guest #5309283
• ▲ useful
▼ not useful
Hi, my friends and I are doing a project for an exam. We are trying to
make a 4-bit up and down counter with the options to stop the
counting,or load a number and then start the count. the problem occurs
when we do the post-route simulation; the output changes when the clock
is at 0, and there are multiple hazards that last for about 25-30 ps.
Can someone help me? what are we doing wrong? here's the code.
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_SIGNED.ALL;
entity esame2 is
    Port ( clock : in  STD_LOGIC;
           reset : in  STD_LOGIC;
           start_stop : in  STD_LOGIC;
           up_down : in  STD_LOGIC;
           value : in  STD_LOGIC_VECTOR (3 downto 0);
           insert : in  STD_LOGIC;
           num : out  STD_LOGIC_VECTOR (3 downto 0));
end esame2;
architecture RTL of esame2 is
signal vet : STD_LOGIC_VECTOR (3 downto 0);
begin
process(reset, clock)
  begin
    if reset = '1' then
      vet <= "0000";
    elsif (clock'event and clock = '1') then
      if(start_stop = '0' and reset = '0') then
        vet <= vet;
  elsif(insert = '1' and start_stop = '1' and reset = '0') then
        vet <= value;
elsif(insert = '0' and reset = '0' and start_stop='1' and up_down
='1')then
        if(vet = "1111") then
          vet <= "0000";
          else vet <= vet + 1;
        end if;
      elsif(up_down = '0')then
        if(vet = "0000") then
          vet <= "1111";
          else vet <= vet - 1;
        end if;
      end if;
    end if;
end process;
num <= vet;
end RTL;
Moderator (Company: Titel) #5309382
• ▲ useful
▼ not useful
Thats normal. For example a overflow transition from 1111 to 0000 or
vice versa like your underflow 0000 to 1111 causes all 4 bits to flip
over. And they won't do it at the very same ps.
And that are no hazarzd, just simple glitches. Those happen in every
synchronous design with every clock cycle all over the world...
> the problem occurs when we do the post-route simulation;
You got it!
Do NEVER perform a post synthesis simulation. You will NOT need it. It
does not give you more useful information than a behavioural (pre
synthesize) simulation can do. A behavioural simulation is all you need
for a synchronous design.
At least I did not perform a post synthesize/translate/route/whatsoever
simulation the last 15 years...
  • [vhdl]VHDL-Code[/vhdl]
