Count number of more than 4 consecutive zeros
OP (Company: LUMS) #5308722
• ▲ useful
▼ not useful
Dear Members,
I am writing a verilog module that can count the number of zeros in my
input data flowing in. Each input sample is 10 bit. And I only want to
count zeros if 4 consecutive samples are zero.
For example, for the input samples:
[74 0 0 0 0 0 54 23 0 0 0 84 0 0 0 0 0 0 12]
I would count the string of first 5 zeros. Then ignore the next 3 zeros
because I only want to consider consecutive 4 zeros only. Then the next
6 zeros are considered. And the total number of zeros become, 5 + 6 =
11.
I have been to count the number of zeros in any string but not able to
accumulate them to get the final answer. I would be much thankful if
someone can guide me. I am attaching my module as well as testbench.
Notice that the test bench reads 10 bit samples from a txt file, namely,
'P281000BSR.txt', the test bench works fine, only the module is to be
rectified.
According to my matlab code, the answer for this txt file should be 127
in decimal.
Moderator (Company: Titel) #5308748
• ▲ useful
▼ not useful
I'm doing VHDL and so I can't serve a solution, but I would do it this
fairly easy way:
I would initially set a sum to 0 and I would set a counter to 0. And
then I would walk through the data and increment the counter every
step I get a 0. When the input data is not 0 then I would compare the
counter with 4 and if its more than 4 then I would add the counter
to the sum and reset the counter to 0.
Moderator (Company: Titel) #5308774
• ▲ useful
▼ not useful
I must correct myself... ;-)
In Verilog this looks like that:
 module BSR(
   input wire clk,
   //input wire clk_enable,
   input wire reset,
   input signed [9:0] data_in,
   output reg [9:0] counter,
   output reg [9:0] acc
   always @ (posedge clk)
   begin
      if(reset)
      begin
         counter = 0;
         acc <= 0;
      end
      else
      begin
         if (data_in == 0)
         begin
            counter = counter + 1'b1;
         end
         else
         begin
            if (counter > 2'b11) begin
               acc <= counter + acc;
            end
            counter = 0;
30
         end
31
32
      end
33
   end
34
35
endmodule
OP (Company: LUMS) #5309138
• ▲ useful
▼ not useful
Dear Miller,
I must say, you are genius. I was so confused about the implementation
in Verilog. Thanks so much. I would be great if you would clarify using
the blocking assignment for counter. Is this a good practice? How does
it affect our design? I was trying to implement the algorithm with
non-blocking (<=) statements only.
Thanks again.
  • [vhdl]VHDL-Code[/vhdl]
