simple syntax error near clk
OP #5307506
• ▲ useful
▼ not useful
Hello , for this simple code i get these  two errors,where did i go
wrong?
Thanks
ERROR:HDLCompiler:806 - "D:\Users\st_line_demo\stln.v" Line 14: Syntax
error near "clk".
ERROR:HDLCompiler:598 - "D:\Users\st_line_demo\stln.v" Line 3: Module
<stln> ignored due to previous errors.
`timescale 1ns / 1ps
module stln(clk,ce,y,c,m);
input clk,ce;
input [7:0] m,c;
output reg [31:0] y;
integer x;
initial
begin
x=0;
end
always @(postedge clk)
 begin
 x=x+1;
 y=(m*x)+c;
 end
 endmodule
OP #5307660
• ▲ useful
▼ not useful
Hello , from this consol massage i can see some points ,
is the problem in the clocks?
1.WARNING:Xst:647 - Input <ce> is never used.
2.
Asynchronous Control Signals Information:
No asynchronous control signals found in this design
Timing Summary:
Speed Grade: -3
   Minimum period: 7.472ns (Maximum Frequency: 133.831MHz)
   Minimum input arrival time before clock: 5.780ns
   Maximum output required time after clock: 0.640ns
   Maximum combinational path delay: No path found
Process "Synthesize - XST" failed
Started : "Synthesize - XST".
Running xst...
Command Line: xst -intstyle ise -ifn "D:/Users/st_line/stln.xst" -ofn
"D:/Users/st_line/stln.syr"
Reading design: stln.prj
*                          HDL Parsing
Analyzing Verilog file "D:\Users\st_line\stln.v" into library work
Parsing module <stln>.
*                            HDL Elaboration
Elaborating module <stln>.
*                           HDL Synthesis
Synthesizing Unit <stln>.
    Related source file is "D:\Users\st_line\stln.v".
WARNING:Xst:647 - Input <ce> is never used. This port will be preserved
and left unconnected if it belongs to a top-level block or it belongs to
a sub-block and the hierarchy of this sub-block is preserved.
    Found 32-bit register for signal <y>.
    Found 32-bit register for signal <x>.
    Found 32-bit adder for signal <x[31]_GND_1_o_add_1_OUT> created at
line 35.
    Found 32-bit adder for signal <m[7]_GND_1_o_add_3_OUT> created at
line 36.
    Found 8x32-bit multiplier for signal <n0010> created at line 36.
    Summary:
  inferred   1 Multiplier(s).
  inferred   2 Adder/Subtractor(s).
  inferred  64 D-type flip-flop(s).
Unit <stln> synthesized.
HDL Synthesis Report
Macro Statistics
# Multipliers                                          : 1
 32x8-bit multiplier                                   : 1
# Adders/Subtractors                                   : 2
 32-bit adder                                          : 2
# Registers                                            : 2
 32-bit register                                       : 2
*                       Advanced HDL Synthesis
Synthesizing (advanced) Unit <stln>.
The following registers are absorbed into counter <x>: 1 register on
signal <x>.
Unit <stln> synthesized (advanced).
Advanced HDL Synthesis Report
Macro Statistics
# Multipliers                                          : 1
 32-bit adder                                          : 2
# Counters                                             : 1
 32-bit up counter                                     : 1
# Registers                                            : 32
 Flip-Flops                                            : 32
*                         Low Level Synthesis
Optimizing unit <stln> ...
Mapping all equations...
Building and optimizing final netlist ...
Found area constraint ratio of 100 (+ 5) on block stln, actual ratio is
0.
Final Macro Processing ...
Final Register Report
Macro Statistics
# Registers                                            : 64
 Flip-Flops                                            : 64
*                           Partition Report
Partition Implementation Status
  No Partitions were found in this design.
*                            Design Summary
Clock Information:
Clock Signal                       | Clock buffer(FF name)  | Load  |
clk                                | BUFGP                  | 64    |
Timing Summary:
Speed Grade: -3
Guest #5308016
• ▲ useful
▼ not useful
Use <= to write to a register, not the blocking = operators.
I would write it like that:
 input clk,ce;
 input [7:0] m,c;
 reg [31:0] x = 0;
 always @(posedge clk) begin
   x <= x+1;
   y <= (m*x)+c;
 end
endmodule
OP #5308550
• ▲ useful
▼ not useful
Hello, i think that the problem is that the "clk" variable is not
defined as clock with period.
how can i define the clk  in ISE Xilinx?
Thanks
module stln(clk,y,c,m);
input clk;
input [7:0] m,c;
integer x;
initial
begin
clk=0;
x=0;
end
begin
x=x+1;
y=(m*x)+c;
end
endmodule
Moderator (Company: Titel) #5308727
• ▲ useful
▼ not useful
You're digging at the wrong place. Thats NOT the problem. The clock
usually is a input and comes from a oscillator or a similar source.
It an input and when you write "posedge" or "negedge" then you invoke
that signal as a clock to some flipflops.
After correcting that assignment to the clk signal it get a successful
synthesizers run with only one warnig:
    Related source file is "stln.v".
WARNING:Xst:643 - "stln.v" line 19: The result of a 32x9-bit multiplication is partially used.
I would set up a new project and copy the source to it. Maybe you
flipped over some switches in the configuration to a faluty position...
OP #5308759
• ▲ useful
▼ not useful
i tried to copy paste the code again,its not working.
i attached the print screen
my new code and the console massage
// Company:
// Engineer:
// Create Date:    15:06:30 02/07/2018
// Design Name:
// Module Name:    stln
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module stln2(clk,y,c,m);
input clk;
input [7:0] m,c;
integer x;
initial
begin
x=0;
end
begin
x=x+1;
y=(m*x)+c;
end
endmodule
Started : "Check Syntax for stln2".
Running xst...
Command Line: xst -intstyle ise -ifn D:/Users/st_line2/stln2.xst -ofn
stln2.stx
Reading design: stln2.prj
*                          HDL Parsing
Analyzing Verilog file "D:\Users\st_line2\stln2.v" into library work
Parsing module <stln2>.
Total REAL time to Xst completion: 3.00 secs
Total CPU time to Xst completion: 3.02 secs
Total memory usage is 219344 kilobytes
Number of errors   :    0 (   0 filtered)
Number of warnings :    0 (   0 filtered)
Number of infos    :    0 (   0 filtered)
Process "Check Syntax" failed
  • [vhdl]VHDL-Code[/vhdl]
