ARM Code for color sensor
#5318768
You could use a pin which generates an interrupt on each rising edge of
the color sensors signal. When you measure the time between the
interrupts you can calculate the frequency.
Guest #5331215
Neethu P wrote:
> Sir,
> I am using TCS3200 color sensor. In the data sheet, it is specified that
> the output of the mentioned sensor is frequency in the form of square
> pulses. How can I find out the frequency value from that output? Anyone
> have the code for TCS3200 color sensor with ARM LPC1769? Please help.
You can connect the pin from the sensor that generates this waveform and
connect it to an Oscilloscope or Logic Analyzer.
Guest #5607355
Neethu P wrote:
> Sir,
can u please share code for tcs3200 colour sensor as i am facing the
same problem........plz
Guest #5609734
charushilakhandait@gmail.com wrote:
> as i am facing the same problem
Uuh, you face the problem that you can't use a search engine with the
terms 'TCS3200 color sensor code' too?
    /*     Arduino Color Sensing Tutorial
     *  by Dejan Nedelkovski, www.HowToMechatronics.com
    #define S0 4
    #define S1 5
    #define S2 6
    #define S3 7
    #define sensorOut 8
    int frequency = 0;
    void setup() {
      pinMode(S0, OUTPUT);
      pinMode(S1, OUTPUT);
      pinMode(S2, OUTPUT);
      pinMode(S3, OUTPUT);
      pinMode(sensorOut, INPUT);
      // Setting frequency-scaling to 20%
      digitalWrite(S0,HIGH);
      digitalWrite(S1,LOW);
      Serial.begin(9600);
    void loop() {
      // Setting red filtered photodiodes to be read
      digitalWrite(S2,LOW);
      digitalWrite(S3,LOW);
30
      // Reading the output frequency
31
      frequency = pulseIn(sensorOut, LOW);
32
      // Printing the value on the serial monitor
33
      Serial.print("R= ");//printing name
34
      Serial.print(frequency);//printing RED color frequency
35
      Serial.print("  ");
36
      delay(100);
37
      // Setting Green filtered photodiodes to be read
38
      digitalWrite(S2,HIGH);
39
      digitalWrite(S3,HIGH);
40
41
42
43
      Serial.print("G= ");//printing name
44
45
      Serial.print("  ");
46
      delay(100);
47
      // Setting Blue filtered photodiodes to be read
48
49
50
51
52
53
      Serial.print("B= ");//printing name
54
55
      Serial.println("  ");
56
      delay(100);
57
Code from the first search engine hit:
https://howtomechatronics.com/tutorials/arduino/arduino-color-sensing-tutorial-tcs230-tcs3200-color-sensor/
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
