Is this nonesense?
OP (Company: Relevant Technologies Ltd) #5281232
• ▲ useful
▼ not useful
Hi
I have multiple clocked processes, all of which must access the same
resources in my ip block. I often end up with something like this:
process(ps_reset_cir_b, reset_cir_cmd_rqst, reset_cir_cmd_out,
        ps_init_cir_b,  init_cir_cmd_rqst,  init_cir_cmd_out,  init_cir_arg_out,
        ps_rx_row_b,    rx_row_cmd_rqst,    rx_row_cmd_out,
        ps_tx_max_b,    tx_max_cmd_rqst,    tx_max_cmd_out,                     tx_max_tready,
        ps_tx_cir_b,    tx_cir_cmd_rqst,    tx_cir_cmd_out,    tx_cir_arg_out,  tx_cir_tready,
        ps_wr_bram_b,   wr_bram_cmd_rqst,   wr_bram_cmd_out,   wr_bram_arg_out,
        ps_rd_bram_b,   rd_bram_cmd_rqst,   rd_bram_cmd_out,   rd_bram_arg_out, rd_bram_tready,
        ps_wr_reg_b,    wr_reg_cmd_rqst,    wr_reg_cmd_out,    wr_reg_arg_out,
        ps_rd_reg_b,    rd_reg_cmd_rqst,    rd_reg_cmd_out,    rd_reg_arg_out,  rd_reg_tready
begin
  if (ps_reset_cir_b = '1') then
    s_axis_cir_tready      <= '0';
    cmd_rqst               <= reset_cir_cmd_rqst;
    cmd_out                <= reset_cir_cmd_out;
    arg_out                <= (others=>'0');
  elsif (ps_init_cir_b = '1') then
    cmd_rqst               <= init_cir_cmd_rqst;
    cmd_out                <= init_cir_cmd_out;
    arg_out                <= init_cir_arg_out;
  elsif (ps_rx_row_b = '1') then
    cmd_rqst               <= rx_row_cmd_rqst;
    cmd_out                <= rx_row_cmd_out;
  elsif (ps_tx_max_b = '1') then
    s_axis_cir_tready      <= tx_max_tready;
    cmd_rqst               <= tx_max_cmd_rqst;
30
    cmd_out                <= tx_max_cmd_out;
31
32
  elsif (ps_tx_cir_b = '1') then
33
    s_axis_cir_tready      <= tx_cir_tready;
34
    cmd_rqst               <= tx_cir_cmd_rqst;
35
    cmd_out                <= tx_cir_cmd_out;
36
    arg_out                <= tx_cir_arg_out;
37
  elsif (ps_wr_bram_b = '1') then
38
39
    cmd_rqst               <= wr_bram_cmd_rqst;
40
    cmd_out                <= wr_bram_cmd_out;
41
    arg_out                <= wr_bram_arg_out;
42
  elsif (ps_rd_bram_b = '1') then
43
    s_axis_cir_tready      <= rd_bram_tready;
44
    cmd_rqst               <= rd_bram_cmd_rqst;
45
    cmd_out                <= rd_bram_cmd_out;
46
    arg_out                <= rd_bram_arg_out;
47
  elsif (ps_wr_reg_b = '1') then
48
49
    cmd_rqst               <= wr_reg_cmd_rqst;
50
    cmd_out                <= wr_reg_cmd_out;
51
    arg_out                <= wr_reg_arg_out;
52
  elsif (ps_rd_reg_b = '1') then
53
    s_axis_cir_tready      <= rd_reg_tready;
54
    cmd_rqst               <= rd_reg_cmd_rqst;
55
    cmd_out                <= rd_reg_cmd_out;
56
    arg_out                <= rd_reg_arg_out;
57
  else
58
59
    cmd_rqst               <= (others=>'0');
60
    cmd_out                <= (others=>'0');
61
62
  end if;
63
end process;
Does this look silly? The various bits indicate the process which is
accessing the mux is active. When all processes are in the idle state,
the final else is active. The various processes, in this case, are
servicing requests from the host cpu. The signals on the left are
interfaces, and each process must use some or all of these.
Best regards
Geoff
Moderator (Company: Titel) #5281244
• ▲ useful
▼ not useful
I can't see absolutely no clock there...
No, ist just the way to write the multiplexer in a process. You could do
it as a concurrent descritpion also.
But the most easy way would be: use VHDL-2008 and write process(all).
Then you could shorten it further on by using default values instead of
the last "else":
process(all)
begin
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
  end if;
45
end process;
OP (Company: Relevant Technologies Ltd) #5282274
• ▲ useful
▼ not useful
Many thanks, I work alone, and still make some godawful blunders, having
been doing this for about two years. Great fun, and a big paradigm shift
from software, a background many will no doubt spot, due to my
parentheses around conditions in if- statements.
OP (Company: Relevant Technologies Ltd) #5282282
• ▲ useful
▼ not useful
The clocked processes are using these resources, and of the usual sort.
They are all state machines, which have an idle state in which they do
nothing at all. So this is combinatorial logic in support of them. They
are assumed to execute exclusively, and, as soon as they enter a state
other than "???_IDLE" the bit is set.
  • [vhdl]VHDL-Code[/vhdl]
