Smoke detector upcycling?
Guest #5273166
Why do you write "working"?
Usually there is no warranty beyond 5 years.
Find your local scrap acceptance in the yellow pages...
Guest #5325037
I think you need to check out your smoke detector by consulting some
professional. You need make sure that they are working with lighting a
match and letting the smoke go into the detectors. If it's not working
properly, then you should buy a new smoke detector and hire your local
electricians to install it. I too had installed new smoke detector by
hiring some electricians Havertown PA (https://www.dndenergy.com) where
they installed it and performed an effective smoke detector test.
#5325063
Mike wrote:
> Any ideas how to use them?
Your question is not clear.
Do you want to use them as smoke detectors, or do you want to build
something else out of them?
You should not use it as smoke detectors any more as the detection unit
gets more and more dirty and the sensor is getting blind over the years.
As an Idea: use them as a signal horn for a water detector unit, for
example to detect water underneath a dish washer or a washing machine.
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
