SNAKE GAME VHDL
OP (Company: enseirb) #5264211
Hi
I am trying to develop a snake game using a Nexys 4 board and oled rgb
screen.
I can't generate automaticaly an other point on the screen when the
snake's head meets the food and while the head is moving . My random
generator(control_pomme) seems to work .  I didn't base my project on
the use of a RAM , do you think it is necessary because  almost all the
snake-like  vga projects on the web seem to use this approach .
Guest #5264307
None of the vhdl-files instantiate each other. Therefore, I cannot
reproduce any tests.
If you need a lot of memory then you can use ram. Otherwise, FFs will do
the job well.
Moderator (Company: Titel) #5264384
Ya Y. wrote:
> Thanks for your reply
           b_up       : in STD_LOGIC;
           b_down     : in STD_LOGIC;
           b_left     : in STD_LOGIC;
           b_right    : in STD_LOGIC;
If those are asynchronous real world buttons, then you must sync them
to your clock. Otherwise you will encouter curious problems.
    type etat is (init, snake_right, snake_left, snake_up, snake_down, snake_pause);
        case etat_present is
        when others => go_up <= '0';     --others = snake_down
Instead of "others" you better should have written "snake_down", because
then there would remain no "others" and the obfuscating "others" clause
would be not needed.
signal sspixcol : unsigned( 6 downto 0 ):="0110000";
signal sspixrow : unsigned( 5 downto 0 ):="100000";
signal noir : STD_LOGIC_VECTOR (15 downto 0) :="0000000000000000";
signal vert : STD_LOGIC_VECTOR (15 downto 0) :="0000001111100000";
        sspixrow <= sspixrow - "000001";
Why don't you work with integers throughout? Then you could use "real
world numbers" instead of unreadable binary codes. And the arithmetic
operations would be much easier to understand...
signal sspixcol : integer range 0 to 127 := 96;
signal sspixrow : integer range 0 to 63  := 32;
        sspixrow <= sspixrow - 1;
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
