Help with VHDL
Guest #5259361
Hello,
I'm quite new to VHDL and trying to create a simple UART transmission in
VHDL code.
This is my code:
entity UART is
  port ( din  : in bit_vector( 7 downto 0) ;
       send : in std_logic ;
       tx  : out bit ) ;
end UART;
architecture arc_UART of UART is
begin
  process
    constant bit_time : time := 8680 ns ;  -- 1/115200 [baud]
  begin
    tx <= '1' ;                -- idle state
    wait until falling_edge(send) ;       -- wait until send
    tx <= '0' ; wait for bit_time ;       -- start bit
    for i in 0 to 7 loop
      tx <= din(i) ; wait for bit_time ; -- send 8 data bits
    end loop ;
    tx <= '1' ; wait for bit_time ;       -- stop bit
  end process;
end arc_UART;
But the problem is that when I run a Model-sim simulation, it doesn't
work as expected.
What could be the problem here?
Thank you
#5259551
I suppose you need something like a loadable shift register plus a
baudrate generator (clock divider),
which generates the shift clock (sclk) from your system clock.
ShiftRegister : process
begin
  wait until rising_edge(sclk);
  if (load = '1') then
    sr(7 downto 0) <= din(7 downto 0);
    tx <= '0';
  else
    sr(6 downto 0) <= sr(7 downto 1);
    sr(7) <= '1';
    tx <= sr(0);
  end if;
end process;
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
