Counter that goes up to 9 and down
OP (Company: nope) #5239772
• ▲ useful
▼ not useful
hello im new to FPGA and ive been trying to make a 4 bits counter that
counts up to 9 and goes down to 0 and then again and again with no
success... so im asking for help for how to do it from anyone who can
help!  thank you. this is what i have right now after some failed
attempts.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity ElevatorCounter is
port (Clock, reset: in std_logic;
      Q            : out std_logic_vector (3 downto 0);
    end entity;
architecture arch_ElevatorCounter of ElevatorCounter is
begin
    process(clock, reset)
          variable tempQ : std_logic_vector(3 downto 0);
  begin
      if Reset='0' then
        tempQ := "0000";
    elsif rising_edge(clock) then
             tempQ :=tempQ + 1;
        if tempQ= "1001" then
          tempQ := tempQ - 1;
            wait until tempQ := "0000";
      end if;
            if tempQ= "0000" then
            tempQ := tempQ + 1;
          wait until tempQ := "1001";
30
          end if;
31
        end if;
32
      end if;
33
    Q <= tempQ;
34
  end process;
35
end architecture;
Moderator (Company: Titel) #5239883
• ▲ useful
▼ not useful
> counts up to 9 and goes down to 0 and then again and again with no success
What about simulating this piece of code?
> wait until...
This will not work in real life here. You are not "programming" with
VHDL. Only about 10% of VHDL are synthesizeble. And those 10% must be
used in a way the synthesizer understands it. The easiest way is to do
it like others do it, the other way is to read the synthesizers manual.
I urge you NOT to use any variables for storing elements. Use signals
instead!
Moderator (Company: Titel) #5240513
• ▲ useful
▼ not useful
My attempt would look like this:
library ieee;
use ieee.numeric_std.all;
  port (clock : in  std_logic;
        floor : out std_logic_vector (3 downto 0));
end entity;
signal d : std_logic := '0'; -- direction 0=up, 1=down
signal f : integer := 0;   -- start at the basement
begin
  process begin
    wait until rising_edge(clock);
    if d='0' then -- up
      if f<9 then
        f <= f+1;
      else
        d <= '1'; -- next: down
        f <= f-1;
      end if;
    else          -- down
      if f>0 then
        f <= f-1;
      else
30
        d <= '0'; -- next: up
31
        f <= f+1;
32
      end if;
33
    end if;
34
  end process;
35
36
  floor <= std_logic_vector(to_unsigned(f,4));
37
38
end architecture;
The result looks fine that far...
OP (Company: nope) #5242477
• ▲ useful
▼ not useful
weird when i try to compile that code i get these errors... help?
Error (10500): VHDL syntax error at elevatorcounter.vhd(9) near text
"end";  expecting an identifier ("end" is a reserved keyword), or
"constant", or "file", or "signal", or "variable"
Error (10500): VHDL syntax error at elevatorcounter.vhd(15) near text
"begin";  expecting an identifier ("begin" is a reserved keyword), or
Error: Quartus II 64-Bit Create Symbol File was unsuccessful. 2 errors,
0 warnings
Moderator (Company: Titel) #5242819
• ▲ useful
▼ not useful
What I get with XST is
Final Register Report
Macro Statistics
# Registers              : 5
 Flip-Flops              : 5
Process "Synthesize - XST" completed successfully
And 5 registers is fine for the desing: 4 for the counter and 1 for the
direction.
Same for Lattice synthesizing engine:
####### Begin Area Report (ElevatorCounter)###########
Number of register bits => 5 of 1604 (0 % )
Done: completed successfully
Same here, so its pretty sure that the Altera toolchain will be able to
synthesize that code.
Pls. attach your VHDL file. Maybe something went wrong with copying...
#5243187
• ▲ useful
▼ not useful
sure it does:
; Flow Summary        ;
; Flow Status                        ; Successful - Thu Dec 14 12:44:06 2017      ;
; Quartus II 64-Bit Version          ; 13.1.4 Build 182 03/12/2014 SJ Web Edition ;
; Revision Name                      ; ElevatorCounter                            ;
; Top-level Entity Name              ; ElevatorCounter                            ;
; Family                             ; Cyclone III                                ;
; Device                             ; EP3C120F484C7                              ;
; Timing Models                      ; Final                                      ;
; Total logic elements               ; 8 / 119,088 ( < 1 % )                      ;
;     Total combinational functions  ; 8 / 119,088 ( < 1 % )                      ;
;     Dedicated logic registers      ; 5 / 119,088 ( < 1 % )                      ;
; Total registers                    ; 5                                          ;
; Total pins                         ; 5 / 284 ( 2 % )                            ;
; Total virtual pins                 ; 0                                          ;
; Total memory bits                  ; 0 / 3,981,312 ( 0 % )                      ;
; Embedded Multiplier 9-bit elements ; 0 / 576 ( 0 % )                            ;
; Total PLLs                         ; 0 / 4 ( 0 % )                              ;
Moderator (Company: Titel) #5243689
• ▲ useful
▼ not useful
Jason J. wrote:
> i didnt change much there it compiled it last time.. :(
So its kind of easy: the problem must be one of those few changes you
made.
Jason J. wrote:
> it happens when i try to compile this piece of code. i attached it.
You simply must remove the errors reported by the toolchain. Start with
that in line 9. Look how a port declaration must look like.
One hint: count all of the brackets. Match the opening brackets to the
closing ones...
> weird for me
Its a little weird for me, that you don't find this little problem
yourself by consulting a VHDL book or some code samples.
  • [vhdl]VHDL-Code[/vhdl]
