Need help in code
OP #5239675
• ▲ useful
▼ not useful
Hello
I'm currently working on my assignment in Spartan-3E.My assignment is:
While button is clicked show values of switches in low 4 bit of LED,when
button is released move from left to right.Switching speed 2Hz.
But i haven't got any success so far.It not even showing values of
switch.
And here is my code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity daalgavar_13 is
Port ( clk : in STD_LOGIC;
       led : out STD_LOGIC_VECTOR (7 downto 0);
       button : in std_logic;
       switch : in  STD_LOGIC_VECTOR (3 downto 0));
end daalgavar_13;
architecture Behavioral of daalgavar_13 is
signal clk_2G: std_logic;
signal tooluur: integer range 0 to 25000000;
signal data : STD_LOGIC_VECTOR (7 downto 0);
 begin
--led<=data;
 process(clk_2G) --, switch)
 variable temp:std_logic_vector(7 downto 0);
 begin
 --if (rst = '0') then
 if clk_2G'event and clk_2G='1' then
30
  if button='1' then
31
   data <="0000" & switch(3 downto 0);
32
  else
33
   temp := data;
34
   data <= temp (6 downto 0)& temp(7) ;
35
  end if;
36
 end if;
37
end process;
38
39
led<=data;
40
41
process(clk)
42
begin
43
 if clk'event and clk='1' then
44
  if tooluur=25000000 then  --2Hz
45
   tooluur<=0;
46
   clk_2G<='1';
47
   else
48
    tooluur<=tooluur+1;
49
    clk_2G<='0';
50
   end if;
51
  end if;
52
 end process;
53
end Behavioral;
Thank you
Moderator (Company: Titel) #5239771
• ▲ useful
▼ not useful
Rock B. wrote:
> where did i go wrong?
First: what does the simulation say?
Second: use your clock enable as a clock enable, not as a clock:
process(clk) -- the one and only clock in the whole design!
begin
      if clk_2G='1' then -- this is the 2Hz clock enable
         if button='1' then
         else
Third, why this:
   temp := data;
And not simply this:
   data <= data(6 downto 0)& data(7) ;
Guest #5239780
• ▲ useful
▼ not useful
Assuming the simulation is fine:
- Are you sure that the pin mapping on your board (ucf) is correct?
- Is the clock source running and at the correct frequency as assumed by
your clock divider?
 Can you monitor clk_2G on an LED?
  • [vhdl]VHDL-Code[/vhdl]
