if error on sequence detector
OP #5238116
• ▲ useful
▼ not useful
Hello, i have the following error on every "if" and "case" line.
i am using quartus 2 'why i get these errors??
Thanks
Error (10500): VHDL syntax error at case_vhdl.vhd(19) near text "clk";
expecting "(", or "'", or "."
Error (10500): VHDL syntax error at case_vhdl.vhd(19) near text "and";
Error (10500): VHDL syntax error at case_vhdl.vhd(32) near text "else";
expecting "end", or "(", or an identifier ("else" is a reserved
keyword), or a sequential statement
Error (10500): VHDL syntax error at case_vhdl.vhd(40) near text "when";
expecting "end", or "(", or an identifier ("when" is a reserved
Error (10500): VHDL syntax error at case_vhdl.vhd(47) near text "when";
Error (10500): VHDL syntax error at case_vhdl.vhd(56) near text "when";
Error (10500): VHDL syntax error at case_vhdl.vhd(63) near text "when";
Error (10500): VHDL syntax error at case_vhdl.vhd(65) near text "case";
expecting "if"
Error (10500): VHDL syntax error at case_vhdl.vhd(70) near text "begin";
expecting ":=", or "<="
Error (10500): VHDL syntax error at case_vhdl.vhd(76) near text
"process";  expecting "if"
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity seqdeta is
 port (clk:in STD_LOGIC;
       clr:in STD_LOGIC;
     din:in STD_LOGIC;
     dout:in STD_LOGIC);
end seqdeta;
architecture seqdeta of seqdeta is
type state_type is (s0, s2, s3, s4);
signal present_state,next_state: state_type;
begin
 sreg: process(clk,clr)
 begin
        if clr='1' then
             present_state<=s0;
        elseif clk'event and clk='1' then
                present_state<=next_state;
         end if;
 end process;
 C1: process(present_state, din)
 begin
   case present_state is
       when s0=>
        if din='1' then
        next_state<=s1;
30
       else
31
         next_state<=s0;
32
      else if;
33
      when s1=>
34
        if din='1' then
35
          next_state<=s2;
36
       else
37
         next_state<=s0;
38
          end if;
39
40
      when s2=>
41
         if din='0' then
42
            next_state<=s3;
43
        else
44
           next_state<=s2;
45
           end if;
46
47
        when s3=>
48
         if din='1' then
49
            next_state<=s4;
50
        else
51
           next_state<=s0;
52
           end if;
53
54
55
56
        when s4=>
57
         if din='0' then
58
            next_state<=s0;
59
        else
60
           next_state<=s2;
61
           end if;
62
63
        when others =>
64
          null;
65
      end case;
66
67
     end process;
68
69
C2: process(present_state)
70
begin
71
   if present_state=s4 then
72
      dout<='1';
73
  else
74
      dout<='0';
75
  end if;
76
end process;
77
end seqdeta;
OP #5238121
• ▲ useful
▼ not useful
Hello , my first error is in the following "if" shown bellow
i used , end if , i ended every statement inside it with ";"
where did i go wrong?
if clr='1' then
             present_state<=s0;
end if;
Thanks
  • [vhdl]VHDL-Code[/vhdl]
