Query regarding 32bits ALU design
OP (Company: STUDENT) #5236789
• ▲ useful
▼ not useful
I want to implement 32bits alu on nexys4 ddr fpga board but there is an
issue regarding I/O pins number board has total 16 input pins so i was
tring to write the code as follow- but i am not getting the simulation
results outputs are coming as unsigned
ibrary IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity alu_32 is
port ( clk,reset : in std_logic;
          sel : in std_logic_vector(2 downto 0);
       a,b : in std_logic_vector(31 downto 0);
       y : out std_logic_vector(31 downto 0) );
end alu_32;
architecture Behavioral of alu_32 is
  --signal a : std_logic_vector(31 downto 0) ;
  --signal  a,b : std_logic_vector(31 downto 0);
  signal count1,count2 : std_logic_vector (1 downto 0);
  signal atemp, btemp ,atemp1, btemp1: std_logic_vector(15 downto 0);
  signal y1,y2  :std_logic_vector(31 downto 0);
  begin
process(clk)
begin
      if (reset='1')then
     y<="00000000000000000000000000000000";
     end if;
    if (rising_edge(clk)) then
      if count1 ="11" then
      count1 <= "00";
      else
      count1 <= count1 + 1;
      end if;
30
    end if;
31
        if  count1 = "00" then
32
       atemp <= y1(31 downto 16);
33
       elsif
34
       count1 = "01" then
35
       btemp <= y1(15 downto 0);
36
       elsif
37
       count1 ="10" then
38
       a<= atemp & btemp;
39
     end if;
40
41
      if  count2 = "00" then
42
       atemp1 <= y2(31 downto 16);
43
       elsif
44
       count2 = "01" then
45
       btemp1 <= y2(15 downto 0);
46
       elsif
47
       count2 ="10" then
48
       b<= atemp1 & btemp1;
49
     end if;
50
end process;
51
PROCESS (sel)
52
begin
53
 case sel is
54
 when "001" => y <=  (a - b) ;
55
 when "010" => y <=  not (a) ;
56
 when "011" => y <=  (a xor  b) ;
57
 when "100" => y <=  (a + b) ;
58
 when "101" => y <=(a and b) ;
59
 when "110" => y <=  (a or b) ;
60
 when others => y <=  (a nand  b) ;
61
 End case ;
62
 end process ;
63
end Behavioral;
64
65
TESTBENCH
66
67
68
LIBRARY ieee;
69
USE ieee.std_logic_1164.ALL;
70
USE ieee.std_logic_unsigned.all;
71
USE ieee.numeric_std.ALL;
72
73
ENTITY test32bit_vhd IS
74
END test32bit_vhd;
75
76
ARCHITECTURE behavior OF test32bit_vhd IS
77
78
  -- Component Declaration for the Unit Under Test (UUT)
79
  COMPONENT alu32
80
  PORT(
81
    clk ,reset: IN std_logic;
82
    sel : IN std_logic_vector(2 downto 0);
83
    a : INOUT std_logic_vector(31 downto 0);
84
    b : INOUT std_logic_vector(31 downto 0);
85
    y : OUT std_logic_vector(31 downto 0)
86
87
  END COMPONENT;
88
89
  --Inputs
90
  SIGNAL clk :  std_logic := '0';
91
  SIGNAL reset :  std_logic := '0';
92
  SIGNAL sel :  std_logic_vector(2 downto 0) := (others=>'0');
93
94
  --BiDirs
95
  SIGNAL a :  std_logic_vector(31 downto 0);
96
  SIGNAL b :  std_logic_vector(31 downto 0);
97
98
  --Outputs
99
  SIGNAL y :  std_logic_vector(31 downto 0);
100
  constant clkperiod : time := 100 ns;
101
102
BEGIN
103
104
  -- Instantiate the Unit Under Test (UUT)
105
  uut: alu32 PORT MAP(
106
    clk => clk,
107
    reset => reset,
108
    sel => sel,
109
    a => a,
110
    b => b,
111
    y => y
112
113
114
  clk_process : process
115
116
117
  BEGIN
118
119
clk <= '0';
120
wait for clkperiod/2 ;
121
clk <= '1';
122
wait for clkperiod/2;
123
end process;
124
125
stimproces : process
126
begin
127
    wait for 100 ns;
128
    wait for 50 ns;
129
130
    reset <= '1';
131
132
133
    wait for 100 ns;
134
    reset <= '0' ;
135
136
    wait for 100 ns;
137
    a <= "01011101010100111110000101100010";
138
    b <= "00111100101011111100111001100111";
139
    --enable <= '1';
140
141
    sel <= "001";
142
143
    wait for 200 ns;
144
    sel <= "010";
145
146
    wait for 200 ns;
147
    wait; -- will wait forever
148
  END PROCESS;
149
150
END;
PLZ tell me the mistake i am doing in writing the codes
Moderator (Company: Titel) #5236819
• ▲ useful
▼ not useful
NIDHI K. wrote:
> i was tring to write the code as follow
Pls read and follow the instructions above every edit box. Here a
summary:
    Post long source code as attachment, not in the text
    [vhdl]VHDL code[/vhdl]
What simulation result do you get and what did you expect?
>    if (reset='1')then
>    end if;
>    if (rising_edge(clk)) then ...
It is not possible to synthesize this, because its some kind of "clock
sensitive despite reset" construct. I'm pretty sure you will not find
such a piece of code elsewhere...
> but i am not getting the simulation results outputs are coming as
> unsigned
Do you 1. not get a result or 2. do you get an unsigned result?
Why the heck an inout here?
The components port must fit the entitys port.
Never ever use both of the packages together, because you may encouter
strange errors due to double type definitions. I urge you to use only
the numeric_std.
> PROCESS (sel)
> begin
In ths process sensitivity list the signals a and b are missing. That
means your simulation is 1. wrong and 2. does not match the reality.
>        elsif
>        count1 = "01" then
>        elsif
>        count1 ="10" then
>        a <= atemp & btemp;
This is kind of nonsense: splitting up a vector y1 and then
concatenating it in three steps to the previous value. What is it good
for?
> entity alu_32 is
An Arithmetic Logic Unit usually does NOT have or need a clock. Why does
yours?
  • [vhdl]VHDL-Code[/vhdl]
