Multiplication fixed floating-point
Guest #5236014
• ▲ useful
▼ not useful
Hello there, i got there another homework as final of semester.
Entering: Create and test the parameterizable implementation of the
integer multiplication algorithm in a fixed floating point. The
parameter must be the number of input bits
operands.
They give us something there as hints:
Let A [n-1: 0],
B [n-1: 0],
Q [n-1: 0],
C [1] and PC are registers.
PC serves as a cycle counter.
Let's put C#Q#A on the label linking registers.
Algorithm of integer multiplication:
BEGIN
C#Q :=0 || PC:=n
WHILE(PC>0)
IF A(0) = 1 THEN
C#Q := Q+B
ENDIF
C#Q#A :=0 # SR1(C#Q#A)||
PC := PC - 1
END
END
After that we got Steps of integer multiplication in binary.
How to start with it? Some solutions? I am so newbie at that
problematics of VHDL codes, scripts.
Moderator (Company: Titel) #5236219
• ▲ useful
▼ not useful
I do not understand what this may be.
I know either "floating point" numbers or "fixed point" numbers.
But a "fixed floting point number" is such a thing like a "flying
submarine".
A "fixed point" number/integer is looking like a normal number/integer.
Only you add a mental position to it which represets a point. The
whole behaviour of the integer always stays the same.
Its a little bit like having a current of 3456 mA in a wire. That is the
very same current like 3.456 A. It is the same current. Just divided by
1000 and therefore getting a point.
So the integer (the current) itself doesn't even "know" that it has a
pinot in it. You can handle it (add, sub, mul...) like a "normal"
integer. Only you must keep an eye on the position of the point:
lets multiply two numbers: 100 * 100 = 10000
When those numbers 100 would be 2.1 fixed point numbers they would
represent 10.0 and the result of the multiplication 10000 must will have
the format 4.2, so you must position the point in a way you have 2
fractional digits: 100.00
Thats the usual multiplication like you do it with a pencil on a sheeet
of paper.
> Q [n-1: 0]
That is wrong. It must be Q[2n-1 : 0] because the result of a
multiplication is as wide as the sum of both inputs width!
Its easy to see: let n be 8, so we get an integer ranging from -128 to
128. So we can easily calculate 100*100 = 10000. Fairly easy to see,
that this result does not fit into -128 to 127...
Write a code for multiplying two unsigned integers without any point.
Wrap that code with a sign-handler. Preform the multiplication of the
fixed integer number like it would be a "normal" integer. Align the
result to the output register in a way that the "point" (which is only a
mental point) is at the correct position. Thats all.
You will need some sheets of paper and a few hours of thougts to get
it...
Guest #5245615
• ▲ useful
▼ not useful
I have read something on forum, where i found this code for
multiplication..
  library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.ALL;
entity MultExample is
Port (C : OUT unsigned (31 downto 0));
end MultExample;
architecture Behavioral of MultExample is
constant A: integer:= 4;
constant B: integer:= 2;
begin
C <=TO_UNSIGNED(A*B,32);
end Behavioral;
There one advanced user told that, C is still 32-bit as result of
multiplication of 2 integers. But how to apply something like that to my
problem? Thanks
Moderator (Company: Titel) #5245653
• ▲ useful
▼ not useful
That means you have n bits wide vectors.
In VHDL you would write (n-1 downto 0).
> problem?
It's a thoroughly correct but in your case absolutely useless
information.
Maybe you asked the wrong question...
Martin wrote:
> It isnt working.. I
What is "it"?
Moderator (Company: Titel) #5246008
• ▲ useful
▼ not useful
Try this:
library IEEE;
Generic ( n  : natural := 16);
Port (a,b : in std_logic_vector(n-1 downto 0),
          c.  : out std_logic_vector(2*n-1 downto 0));
end MultExample;
begin
    c <= std_logic_vector(unsigned(a)*unsigned(b));
end Behavioral;
Guest #5246140
• ▲ useful
▼ not useful
You had one error in your code, i fixed it. Code is working, Waveform
simulation too.
How can i put my A[n-1 : 0] to code? Only put that to Port like:
A : in std_logic_vector(n-1 downto 0);
Nothing else?
How about testing with Altera..I need testbench right? Some advices to
vhdl code at entity?
I don't have so much time for realization.
Guest #5246443
• ▲ useful
▼ not useful
How to set C as 1 it will be input i think...
Can you tell me? Thanks a lot! Compilation is unsucessful.
library IEEE;
Port (A,B,Q : in std_logic_vector(n-1 downto 0);
        C  : std_logic:='1';
      PC : in std_logic_vector(n-1 downto 0));
end MultExample;
begin
C#Q :=0 || PC:=n
WHILE(PC>0)
IF A(0) = 1 THEN
C#Q := Q+B
ENDIF
PC := PC - 1
END
END
end Behavioral;
Is alghoritm ok in Behavioral? Or it must be in process or something
like that? Thanks a lot for help.
Moderator (Company: Titel) #5246468
• ▲ useful
▼ not useful
It's a pseudo language. The synthesizer will not understand it. It will
produce lots of errors.
Why Q?
My best hint ist to discuss this little piece of homework with one of
your classmates! I can't see no progress here with that topic. We are
discussing about things on a level similar to 1+1 in arithmetics...
Guest #5246583
• ▲ useful
▼ not useful
Pseudo language? How now use it? Must i remake it to VHDL format? Or
where attach it? No one from my classmates got similar homework. What is
Q?
I got homework: A, B, Q, C, PC are registers, PC is cycle counter.
Please help me. I can not do that alone.
Moderator (Company: Titel) #5246715
• ▲ useful
▼ not useful
First you must understand the algorithm in those lines. Then you can
convert them to VHDL.
The inputs are two operands as vectors and the output is one vector of
(curiously) the same length.
The PC (name it progress counter) and the C (name it carry) are only
local signals.
Indeed the text of that exercise is wrong (or at least misleading),
because due to the fact that a multiplication is thoroughly
combinatorial there are no registers needed to get the result.
Guest #5246743
• ▲ useful
▼ not useful
I don't know how to format pseudo code to VHDL code. Yes, i understand
to that there are 2 inputs A, B. Q is output of same lenght, because it
got parameter n-1 downto 0.
Understand. But i don't have experiences to make code to VHDL script
from that pseudo code. Can you help me little bit with some VHDL demo
with my variables please?
Guest #5246753
• ▲ useful
▼ not useful
library IEEE;
        C  : std_logic:='1';
end MultExample;
BEGIN
  C#Q := 0 || PC := n
  WHILE (PC > 0)
    IF A(0) = 1 THEN
      C#Q := Q + B
    END IF
    C#Q#A := 0 #SR1(C#Q#A) ||
      PC := PC - 1
    END
  END
end Behavioral;
Can you edit it please?
Guest #5246773
• ▲ useful
▼ not useful
library IEEE;
Port (A,B : in std_logic_vector(n-1 downto 0);
      C  : std_logic:='1';
      Q : out std_logic_vector(n-1 downto 0);
end MultExample;
BEGIN
  Q <= std_logic_vector(unsigned(A) * unsigned(B));
end architecture Behavioral;
How about something like that? Can you help me?
  • [vhdl]VHDL-Code[/vhdl]
