linking an output in one entity to the input of another entity
OP (Company: none) #5228386
• ▲ useful
▼ not useful
If i have two entity's:i.e
entity 1
port(
send:out standard_logic;
end
architecture
(function carried out)
send<=signal
end
entity 2
port(
receive:in standard_logic;
end
architecture
end
this code is a basic concept of the task i am trying to carry out.
I have tried to link send in entity 1 with receive in entity 2,i have
tried port map but i hasn't worked.
are signals a better way of connecting the two entity together.
input receive (in entity 2) <= signal send in entity 1.
does this need port map in each body of the architecture.
Moderator (Company: Titel) #5228419
• ▲ useful
▼ not useful
What didn't work with what error message?
Read the chapter "component instantiation" and afterwards the chapter
"port map" in any VHDL book.
Having done that you will see tere are 2 ways:
a. instantiate entity 2 as a component in entity 1and simply assign the
port signals
b. wirte a third entity, instantiate both of the entities 1 and 2 as
components and wire them together using a local signal.
The second way is the most probable way in your case..
As already said a few times ago (eg in
https://embdev.net/topic/440226?goto=5227182#5227123 ):
pls use the [vhdl] tags to wrap your code...
OP (Company: none) #5229358
• ▲ useful
▼ not useful
I have managed to get it to connect now,i did not realize you have to
include all of the ports in the entity, i thought that inside the
brackets()would indicate the specific port only.
connection:entity work.entity(entity_architecture)
port(transmission,in1)
it forced me to include reset,clock etc.
  • [vhdl]VHDL-Code[/vhdl]
