std_logiv_vector
OP (Company: none) #5227083
i am trying to send positive and negative numbers as part of an array to
an output.
like [12,0,6,5-6,-7,-78] for example as a 7 bit array
dataflow:out (6 downto 0)
Type  dataflow is array ( 0 to 6) of std_logic_vector (6 downto 0);
signal data1: dataflow :=(12,0,6,5-6,-7,-78)
dataflow<=data1
i have tried lots of ways making the logic vector an integer array but
cant seem to find a way of either storing it in this way or adding the
values once converted to a positive or negative integer.
is this way far to complex?
Moderator (Company: Titel) #5227123
How can this work? data1 contains 7 std_logic_vectors, you cannot assign
integer numbers to them...
What do you want at all?
BTW: pls use the [vhdl] tags wrapped around your VHDL code like
described in the "formatting options" a few lines above every edit box.
OP (Company: none) #5227147
srry some of my explanation was missing
(12,0,6,5,-6,-7,-78)
i would like to send this type of information to an output and thought i
would need to put it into an array 7 long.
i have little programming experience in vhdl
each time a clock cycle happens i want the next integer to be sent, is
it better to use case statements to do this or can i create an array
with seven values inside that release another integer on a clock cycle.
thnx
Moderator (Company: Titel) #5227164
Richard T. wrote:
> or can i create an array with seven values inside that release another
VHDL has a very strict type handling.
You cannot simply assign an integer to a std_logic_vector!
One thing in advance: -78 does not fit in 7 bits!
Having cleared that I would do it this way:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
type dataflow is array (0 to 6) of integer range -128 to 127;
signal data  : dataflow := (12,0,6,5-6,-7,-61);
signal index : integer range 0 to 6 := 0;
  dataflow <= std_logic_vector(signed(data(index),7));
OP (Company: none) #5227182
i will play with this,i set the 7 bits thinking i was partitioning 7
bits of data but i see your using the space to generate the integer.
i used very similar code hours ago but i had range at 0 to 7 and i
didn't have the signal index. i guess this is a sub type of the array
showing length?
thank you for helping i been working on this for days and couldn't find
any similar examples to try and understand the manipulation of the code.
OP (Company: none) #5227218
this expression is contained within the architecture.
where in the body of the program does this fit?
this indicates the makeup of the array but if i want to connect it to an
output, output_1<=data wont suffice will it. does the output have to be
of a certain type e.g integer or std_logic_vector(7 downto 0)
Moderator (Company: Titel) #5227238
Richard T. wrote:
> the signal index. i guess this is a sub type of the array showing length?
It is what you wanted, when you increment the index every clock cycle:
Richard T. wrote:
> an array with seven values inside that release another integer on a
> clock cycle.
So, lets finish it up:
library ieee;
entity PatternGenerator is
    Port ( clk : in  STD_LOGIC;
           pattern : out  STD_LOGIC_VECTOR (6 downto 0));
end PatternGenerator;
architecture Behavioral of PatternGenerator is
  type dataflow is array (0 to 6) of integer range -64 to 63;
  signal data  : dataflow := (12,0,6,5,-6,-7,-38);
begin
  process begin
     wait until rising_edge(clk);
     if index<6 then  index <= index+1;
     else             index <= 0;
     end if;
  end process;
  pattern <= std_logic_vector(to_signed(data(index),7));
end Behavioral;
After applying a clock it looks as expected...
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
