Verilog 16 bit RISC Microprocessor
Guest #5224138
• ▲ useful
▼ not useful
Ok, so I need some help with a verilog self learning project I'm working
on.
I'm building a 16 bit RISC microprocessor. I'm on the last 3 modules
before major testing and I'm stuck on the second one. The instruction
decoder. I'll have a diagram to explain what I'm talking about. The
module takes a 16 bit input
First 4 bits raise a flag that corresponds to the instruction (ex. MOV,
ADD, ADDI, SUB, NOT, AND, OR, etc.) the last 12 bits break down into 6
and 6 for holders to do the operation. I've also attached my code to
what I think is correct. Does this look ok? Is this how you would
implement this? Did I over complicate it.
Moderator (Company: Titel) #5224205
• ▲ useful
▼ not useful
I'm not the Verilog pro, but as far as I see, you kind of assign the op
to itself...
Why the doublestep with assigning op codes to the op codes? I would do
it somehow this way without the if-query:
  always @* begin
    op = instruction[15:12];
    param1 = instruction[11:6];
    param2 = instruction[5:0];
  end
  always @(posedge clk)
    case (op)
      4'b0010: //pick the FSM that does MOV with param1 & param2
      4'b0011: //pick the FSM that does ADD with param1 & param2
      4'b0100: //pick the FSM that does ADDi with param1 & param2
      4'b1101: //pick the FSM that does LOAD with param1 & param2
      4'b1110: //pick the FSM that does STORE with param1 & param2
    endcase
BTW: this is not a 16-Bit processor, because its operands are
obviously only 6 bits wide. Therefore I would call it a 6 bit processor.
Otherwise the AVR family also would be a 16 bit processor, because the
command word width within them is 16 bits...
#5224301
• ▲ useful
▼ not useful
Here you will find an example code of a very small and simple CPU.
https://embeddedmicro.com/tutorials/lucid/basic-cpu
It is very fast, simple, and it is running fine.
Hope you will find an inspiration for your project.
This is written in Lucid.
But Lucid will be compiled into Verilog.
Download the free Mojo IDE and compile this example.
You will find the Verilog code in a sub directory.
  • [vhdl]VHDL-Code[/vhdl]
