Case Statement outside Process Block
OP (Company: Lab Instructor) #5222745
• ▲ useful
▼ not useful
case sel is
when '0' => o <= i(0);
when '1' => o <= i(1);
when others => o <= 'U';
end case;
The above case statement when put outside a process block gives a syntax
error and I am forced to put the case statement inside a process block
although I do not feel the need to do the same.
Can anyone explain what is the restriction that VHDL is imposing because
of which I am forced to define the case statement within the process
block.
Thanks in advance.
Moderator (Company: Titel) #5222927
• ▲ useful
▼ not useful
> block.
There are different syntax elements to do such things outside an
process. Read about "concurrent assignments" (=without process) vs.
"sequential statements" (=inside a process).
sequential coding:
process (i) begin
  case sel is
  end case;
end process;
concurrent coding:
o <= i(0) when sel='0' else
     i(1) when sel='1' else
     'U';
#5223101
• ▲ useful
▼ not useful
> block.
The (rather unsatisfying but correct) answer is probably: because that's
the way it is. You might as well ask why there is no concurrent "if"
statement. I would assume language designers did it this way to make it
clear to the coder that there are significant differences between
sequential and concurrent and allowed only one-liners for the latter.
Maybe the "selected concurrent signal assignment" is what you are
looking for. Although kind of backwards, it's basically the same thing:
with selector select
    target <= value1 when choice1,
    target <= value2 when choice2,
    target <= default_value when others;
  • [vhdl]VHDL-Code[/vhdl]
