Integer Assignment to STD_LOGIC_VECTOR
OP (Company: Lab Instructor) #5221815
For a 3-8 Decoder my IO ports are as below:
d : in STD_LOGIC_VECTOR (2 downto 0);
o : out STD_LOGIC_VECTOR (7 downto 0));
In my VHDL code, I am trying to mimic a Verilog assignment where d is
used in the case statement as the case parameter and o is the output.
Verilog syntax is as below:
3’d7: o=8’d1;
In my VHDL case statement I could come up with the below assignment
case d is
when "111" => o <= STD_LOGIC_VECTOR(TO_UNSIGNED(1,8));
Is there an easier way of doing the same without using Type conversions
in VHDL. Something like the code below (Although this will return a
compile error).
case d is
when 7 => o <= 1;
Thanks in advance.
Also, could someone explain how the type conversions is working using
the below syntax.
Guest #5221957
> case d is
> in VHDL.
There are literals in VHDL. It's either like x"1" or 16#1#. You can try
one of those or search for "literals".
> the below syntax.
What do you want to know? Why it has to be this way?
Unsigned is just another interpretation of a std_logic_vector. A
std_logic_vector is a string of independent bits, whereas unsigned is a
positive (or zero) number represented by those bits. That's why you can
simply cast between unsigned and std_logic_vector.
An integer is a number, which has nothing to do with VHDL bits. So you
have to convert the integer into a bit representation via a conversion
function. That's why you have to give the length as parameter. The
integer 1 could be represented as binary "1", "01", "001", so the
compiler has to know, how long the unsigned vector is.
Of course you could write a function to_std_logic_vector. There just
isn't one in numeric_std (as far as I know).
Moderator (Company: Titel) #5222965
Dussel wrote:
> There just isn't one in numeric_std (as far as I know).
No, it isn't. And when the design is done with a little bit thinking
about structure and layout there are just a few lines with that "double
step". And the proposed to_std_logic_vector() is just a few letters
shorter, but it doesn't skip the conversion...
Rejoy M. wrote:
> case d is
When you want to assgin a value to a std_logic_vector you can do it with
"00000001". So why starting with an integer?
> compile error).
> case d is
> when 7 => o <= 1;
Simply implement two local integer signals dl and ol and do it this way:
signal dl : integer range 0 to 7;
signal ol : integer range 0 to 255;
dl <= to_integer(unsigned(d));
-- use dl througout the code
case dl is
 when 7 => ol <= 1;
o <= std_logic_vector(to_unsigned(ol,ol'length));
AND AN ADDITIONAL HINT: DO NOT USE CAPITALS AS FUNCTION NAMES. IT MAKES
THE CODE NEARLY UNREADABLE, BECAUSE THE BRAIN IS IT NOT USED TO READ
WORDS IN CAPITAL LETTERS!
BTW: pls wrap your VHDL code with the [vhdl] tags...
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
