VHDL code for Rnon Snon (NAND) Flip flop
Guest #5220499
It is negated R and negated S and flip flop based on NAND..
I don't know how to realize it. I have sent that code to my teacher and
she said: It isnt that what she need...
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity rs_nand is
Port (
      r,s,clk : in  STD_LOGIC;
      q,qb : inout STD_LOGIC
end rs_nand;
architecture rs_nand_arch of rs_nand is
signal temp1,temp2:STD_LOGIC;
component nand21
port(
      a,b: in STD_LOGIC;
      y:out STD_LOGIC
end component;
begin
n1: nand21 port map(a=>r,b=>clk,y=>temp1);
n2: nand21 port map(a=>clk,b=>s,y=>temp2);
n3: nand21 port map(a=>temp1,b=>qb,y=>q);
n4: nand21 port map(a=>q,b=>temp2,y=>qb);
30
31
end rs_nand_arch;
32
33
34
library IEEE;
35
36
37
38
39
entity nand21 is
40
Port (
41
         a,b : in  STD_LOGIC;
42
         y : out  STD_LOGIC
43
44
end nand21;
45
46
architecture nand_arch of nand21 is
47
begin
48
y <= a nand b;
49
end nand_arch;
Moderator (Company: Titel) #5220693
Maybe you can post the whole piece of homework?
And maybe its related to some excersie before it?
Those packages are absolutely needless here because no kind of any
calculation is done:
One word to your port list:
clk? For what?
Thats all?
Guest #5234057
Hey there, i got code.. Now i want testbench for it.. can you help me?!
Thanks!
library IEEE;
entity rs_nand is
Port (
      r,s: in  STD_LOGIC;
end rs_nand;
signal tmp_q, tmp_qb : STD_LOGIC;
begin
tmp_q <= s NAND tmp_qb;
tmp_qb <= r NAND tmp_q;
q <= tmp_q;
qb <= tmp_qb;
end rs_nand_arch;
Moderator (Company: Titel) #5234077
Martin wrote:
> can you help me?! Thanks!
For sure.
Start with something and when encounter a specific problem, THEN ask.
But don't try that "who is doing my homework" story...
That is no geood design practice.
Why the heck should q and qb have an input function? Use a buffer or
an out port.
Guest #5234191
Sir. We don't know how to program in VHDL. In our school we are only
learning to read what is in code and of what it is doing.. They want
from us to make Rnot Rnot flip flop with test bench that can be tested
in ModelSim Altera of Quartus 13.1 SP. I don't know what to do. With
outputs you are true.
Moderator (Company: Titel) #5234241
So first start with a empty "testbench" how it can be found everywhere
in books and on the internet: a VHDL file with an empty port list, in
which the DUT (device under test) is invoked as a component. Thenn add
some local signals, connect them to the flipflop ports and generate a
test pattern for the two inputs.
The whole test bench can be done in somewhat around 30 lines here,
because in the first step you don't need to verify the results, instead
just generate a waveform in the simulator.
It took me about 5 minutes, but it will help you no further when I
just give you that "testbench". So start with something and then we
discuss.
BTW: I attached the corrected RS flipflop file. The arith package was
unnecessary also...
Guest #5234925
Hello there, thanks for reply, code working good and Waveform simulation
too, i tried to make test bench file, but i have problems with it.. It
draw something in Altera ModelSim. I zoomed to full but i got there only
"bars" from left to right full of green color.
I remember we had one homework months ago and there was something like
UUT in test bench and i wrote it to Assignments --> Settings --> Test
bench file but u dont know where take it now.
Actual VHDL TB code:
library IEEE;
entity rs_nand is
   port(r, s : in std_logic;
           q, qb : out std_logic);
end rs_nand;
begin
  q  <= tmp_q;
  qb <= tmp_qb;
end rs_nand_arch;
library ieee;
use ieee.std_logic_1164.all;
entity rs_nand_tb is
end rs_nand_tb ;
architecture tb of rs_nand_tb  is
   component rs_nand is
   end component;
   signal r, s, q, qb : std_logic;
30
31
begin
32
 mapping: rs_nand port map(r, s, q, qb);
33
34
 process
35
36
 begin
37
 -------------TEST 1
38
   s <= '0';
39
   r <= '0';
40
   wait for 10 ns;
41
   assert(q = '1') report "Error 1"  severity error;
42
   assert(qb = '1');
43
  ----------TEST 2
44
   s <= '0';
45
   r <= '1';
46
   wait for 10 ns;
47
   assert(q = '1');
48
  assert(qb = '0');
49
   ----------TEST 3
50
   s <= '1';
51
   r <= '0';
52
   wait for 10 ns;
53
   assert(q = '0');
54
  assert(qb = '1');
55
  ----------TEST 4
56
   s <= '1';
57
   r <= '1';
58
   wait for 10 ns;
59
   assert(q = q);
60
  assert(qb = not q);
61
62
    end process;
63
end tb;
64
configuration cfg_tb of rs_nand_tb is
65
   for tb
66
   end for;
67
end cfg_tb;
Guest #5234957
It is working! But i haven't edited test bench file. That time ago it
draws full lines, like 0 and 1 together with that "width" between them.
Now it looks good, But why it didn't automatically change values?
Guest #5235031
Yes, i click on stop and then Zoom. But values didn't change. What must
i change in TestBench file to make something like randomize after 50ns
etc.. I am very happy for that i alone wrote whole TestBench script.
Guest #5235387
The files work perfectly in modelsim too:
$ vcom nand.vhd
vcom nand.vhd
Model Technology ModelSim SE-64 vcom 10.6c Compiler 2017.07 Jul 26 2017
-- Loading package STANDARD
-- Loading package TEXTIO
-- Loading package std_logic_1164
-- Compiling entity rs_nand
-- Compiling architecture rs_nand_arch of rs_nand
-- Compiling entity rs_nand_tb
-- Compiling architecture tb of rs_nand_tb
-- Compiling configuration cfg_tb
-- Loading entity rs_nand_tb
-- Loading architecture tb of rs_nand_tb
Errors: 0, Warnings: 0
$ vsim -gui rs_nand_tb
vsim> add wave *
vsim> run 60 ns
Use the zoom fit function in wave window to show everything.
Duke
Guest #5236999
Hey, what must i add to my code and how to make it correctly?!
Teacher told me that: I have RnotSnot, but it is negated RS. So i must
add to code RS too. For that i must make invertor.
I tried
r <= not rnot
s <= not snot
VHDL Compilation error: Error (10568): VHDL error at rs_nand.vhd(14):
can't write to interface object "r" of mode IN
i cannot negate it, because it is input. What now?
library IEEE; --kniznica IEEE
use IEEE.STD_LOGIC_1164.ALL; --pouzitie IEEE.STD_LOGIC pre vyuzitie STD_LOGIC FUNKCII
entity rs_nand is -- popis entity
Port (r,s,rnot,snot: in  STD_LOGIC; -- definovany port s log.vstupmi R, S
      q,qb : out STD_LOGIC); -- VYSTUPY Q QB
end rs_nand; --koniec popisu entity
architecture rs_nand_arch of rs_nand is --popis architektury
signal tmp_q, tmp_qb : STD_LOGIC; -- vytvorenie logickych signalov tmp_q a tmp_qb
begin
r <= not rnot;
s <= not snot;
  tmp_q  <= snot NAND tmp_qb; -- popis signalu architektury na NAND hradle
  tmp_qb <= rnot NAND tmp_q; -- popis signalu architektury na NAND hradle
  q  <= tmp_q; -- priradenie signalu tmp_q pre vystup q
  qb <= tmp_qb; -- priradenie signalu tmp_qb pre vystup qb
end rs_nand_arch; --koniec popisu architektury
Moderator (Company: Titel) #5237020
Use "brain 1.0" and start thinking. If thats way tooooooo difficult,
then simply place this lines to the correct position:
Port (rnot,snot: in  STD_LOGIC;
signal r,s : std_logic;
r <= not rnot;
s <= not snot;
> I tried
Bad idea.
Take any beginners book about logic and have a look at the RS flipflop.
How many inputs does it have?
Right: two, in numbers 2.
Why does your RS flipflop have 4 inputs?
Guest #5246854
Altera ModelSim simulation didnt work!
Can you please help me?!
VHDL file:
Port (rnot,snot: in  STD_LOGIC; -- definovany port s log.vstupmi R, S
signal r,s : STD_LOGIC;
begin
r <= not rnot;
s <= not snot;
TB file:
use IEEE.STD_LOGIC_1164.ALL; --pouzitie log. funkcii STD_LOGIC
entity rs_nand is --opis entity
   port(rnot, snot : in std_logic;
end rs_nand;
signal r, s : STD_LOGIC;
begin
r  <= not rnot;
s  <= not snot;
  q  <= tmp_q;
  qb <= tmp_qb;
end rs_nand_arch;
library ieee;
entity rs_nand_tb is --entita testbench
end rs_nand_tb ;
architecture tb of rs_nand_tb  is --architektura
   component rs_nand is -- komponent rs_nand je komponentom architektury tb, ktora je pod entitou rs_nand_tb
      port(rnot, snot : in std_logic; --port komponentu s vstupmi
             q, qb : out std_logic); --vystupmi
   end component; --uknceny popis komponentu
30
31
   signal rnot, snot, q, qb : std_logic; --logicke signaly, ktore je mozne dalej opisat v port mappingu
32
33
begin
34
 mapping: rs_nand port map(rnot, snot, q, qb); --mapovanie portov pre danu entitu
35
36
 process --opis procesu. V procese je kod rovnocenny
37
    --s <= '0'; a r <= '0';
38
  -- je to isté ako  r <= '0'; a s <= '0';
39
  --rychlost vykonavania krokov v procese je identicka, nezalezi na poradi, riadku v kode
40
 begin --zaciatok opisu procesov (ktore mozu nastat, stavy)
41
 -------------TEST 1
42
   snot <= '0';
43
   rnot <= '0';
44
   wait for 10 ns;
45
   assert(q = '1') report "Error 1"  severity error; --zakazany stav
46
   assert(qb = '1'); --funkcia assert vie nastavit stav výstupu, moze aj referovat chybu!
47
  ----------TEST 2
48
   snot <= '0';
49
   rnot <= '1';
50
   wait for 10 ns;
51
   assert(q = '1'); --
52
  assert(qb = '0');
53
   ----------TEST 3
54
   snot <= '1';
55
   rnot <= '0';
56
   wait for 10 ns; --10ns caka v tomto stave
57
   assert(q = '0');
58
  assert(qb = '1');
59
  ----------TEST 4
60
   snot <= '1';
61
   rnot <= '1';
62
   wait for 10 ns;
63
   assert(q = q);
64
  assert(qb = not q);
65
66
    end process; --koniec opisu procesov
67
end tb; --koniec opisu architektury tb
68
configuration cfg_tb of rs_nand_tb is --konfiguracia test bench entity
69
   for tb --cyklus je prazdny, nema ziadnu specificku funkciu v nasom pripade
70
   end for; --koniec cyklu
71
end cfg_tb --koniec opisu konfiguracie
Moderator (Company: Titel) #5247309
Why? What errror messages do you get?
What do you expect? And what do you get instead?
Martin wrote:
> VHDL file:
> TB file:
Why are there two entities with the same name?
To get things clear: in a beginners design in the testbench file there
is only 1 entity declaration. It is that one without ports.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
