8-bit counter with enable VHDL
OP (Company: VGTU) #5219267
Hi guys.I need to write code for counter with input ENABLE and
synchronous reset. The сounter must count up to 19. I have this code,
but I don't understand where there is an error. Help me please anybody
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity UP_COUNTER is
    Port ( clk: in std_logic; -- clock input
           reset: in std_logic; -- reset input
           ce: in std_logic; -- enable input
           counter: out std_logic_vector(7 downto 0) -- output 4-bit counter
end UP_COUNTER;
architecture Behavioral of UP_COUNTER is
    signal counter_up: std_logic_vector(7 downto 0);
begin
-- up counter
process(clk)
begin
    if rising_edge(clk) then
        if reset = '1' then
            counter_up <= (others=>'0');
        elsif ce = '1' then
            M1: for i in 0 to 19
          loop
          counter_up <= counter_up + i;
        end loop;
        end if;
    end if;
 end process;
30
    counter <= counter_up;
31
end Behavioral;
Guest #5219276
The keyword 'loop' marks the lines with errors.
PS:
Ваши английские предложения звучат больше немецкого, чем русского.
Guest #5219449
1) remove/replace everything that belongs to the "loop" construct ->
   you'll end up with a line:
    counter_up <= counter_up + 1;  --note the '1' instead of i
2) then simulate and think
 -how to detect the upper bound of the counting range
 -how to set the counter to the lower bound
-> then you will end up with a counter that works.
If you wanna improve your code further, think about an appropriate type
for the counter_up value i.e. 'unsigned' instead of 'std_logic_vector'.
And stay improving the code by using type 'integer' with 'range'
constraint.
Moderator (Company: Titel) #5219450
Dmitry O. wrote:
> Where is the error? Tell me please
First: pls wrapp your VHDL code in the VHDL tags
[vhdl]
  VHDL code
[/vhdl]
Second: do not use comments when they tend to be wrong or completely
needless, such as this
Of course "clk: in std_logic" is the "clock input" andsoforth. And then
(7 downto 0) is 8 bits, not 4 bits!
Third: forget what you know about loops from C or any other
programming language. A loop in VHDL ist somthing COMPLETELY
different.
Fourth: do not use the outdated std_logic_arith packages. Use the
numeric_std instead!
See the conversion chart there
http://www.lothar-miller.de/s9y/categories/16-Numeric_Std
Finally try this and think about it:
library IEEE;
use IEEE.NUMERIC_STD.ALL;
           ce: in std_logic;
end UP_COUNTER;
    signal counter_up: integer range 0 to 19 := 0;
begin
-- up counter
process(clk)
begin
        if reset = '1' then
           counter_up <= 0;
        elsif ce = '1' then
           if counter_up<19 then
           else
              counter_up <= 0;
           end if;
        end if;
    end if;
30
 end process;
31
    counter <= std_logic_vector(to_unsigned(counter_up,8));
32
end Behavioral;
Only registered users may reply in this topic.
or
Registration is free and takes only a minute.
Register now
