I am currently converting some Verilog into VHDL that goes quite well till now : I don't know how to handle that expression' ' 8b'001100111 I checked I really need only 8 bits ... so obviously there's one extra bit in this expression ... and the Verilog code was "working" You have any idea which bit is "forgotten".... the first 0 ... or the last 1 ?? Thank you
Sylvain N. wrote: > I checked I really need only 8 bits ... so obviously there's one extra > bit in this expression ... and the Verilog code was "working" See there at "integer numbers": http://www.asic-world.com/verilog/syntax1.html "... the leftmost bits are truncated."
Thank you so much
