Unknown Micro
OP #5205135
Can anybody tell me the manufacturer/pinout of the following micro. I am
trying to convert a thermoelectric wine cooler to a fridge and would
like to modify the control circuit.
Any help or direction would be welcome.
https://ibb.co/mTUMAw
Cheers,
Alspa
Guest #5205153
I can't answer your question.
However, there should be some sort of temperature sensor which is the
more interesting part. In easierst case you can simplay replace that by
another sensor to shift the temperature range.
You should keep in mind that not all colling devices can be converted to
a fridge due to limitations of the chemical components. If the colling
fluid freezes, then it stops working.
Guest #5205158
What do you mean "colling devices" and "colling fluid"?
Do you mean "cooling"?
OP #5205515
Its a thermoelectric cooling deice so no compressor or cooling fluid. It
has a NTC thermocouple for temperature sensing and a peltier with
heatsink and fan for heat removal. It seems to apply a PWM to the
peltier afeter reading the temperature. It can only be set to cool down
to to 7degrees and I want it to go down to 4 degrees if possible.
Just adjusting or offsetting the the temperature feedback is not an
answer asI need the front display to still read correct and this would
be driven by the NTC.
Cheers,
Alspa
Guest #5242220
Hi, can you make a puicture from the bottom to see where VCC/GND go.
That would give us a clue what it could be.
rgds
Start a new thread
