I am currently working on an old board which have old FPGA SPRTAN which its not available on market on board and i dont have a source code for those FPGA's except for .bit file which was downloaded through VME bus. Currently i am redesigning the board eliminating all the PAL's on the board with high end FPGA and also want to incorporate the obsolescence spartan into them.But i dont have a source code except for .BIT (Bitstream)file. Is there any software which could convert the .bit file to VHDL/ Verilog?or even a functional block? Any alternative suggestions to go ahead with this board redesign ? Thank you osama
Osama E. wrote: > Is there any software which could convert the .bit file to VHDL/ > Verilog?or even a functional block? I think the FPGA vendor (Xilinx) has a tool for such task, but I never heard that such tool is offical availibe for customers. > Any alternative suggestions to go ahead with this board redesign ? Ask the designer, take a look at the development documentation, guess the function and redesign... Duke
