I have this code, but I need help to modify it in order to use the t flip flops to simulate 4 leds that light up on each clock like this: 0 = led on x = led off clk 1: 0000 clk 2: 000x clk 3: 00xx clk 4: 0xxx clk 5: xxxx clk 6: xxx0 clk 7: xx00 clk 8: x000 (then it loops back to how it was in the first clock on the 9th clock.) Thanks for the help
Nick D. wrote: > but I need help to modify it So first will be to add the fourth flipflop. And then implement the transition terms for the 8 transitions. It will be less typewriting when you reduce the logic terms by using state of the art tools like Karnaugh maps in advance. > I have this code And what does it do? Examine it and think about what to add to get your job done. > Thanks for the help Its not the intention of this forum to do your homework. So start with something and when you have a particular problem, then ask.
