How to implement a shift and decimal point on a time multiplexer
Guest #5174951
• ▲ useful
▼ not useful
I am a student and I recently learned how to create VHDL code for
displaying 4 digit time multiplexer on a coolrunner board. I am trying
to expand my knowledge and learn how to make the digits slide(left or
right) like they would on a billboard so when a digit slides left, it
would slide into the rightmost display. I am also trying to use the
decimal point on the display and how to make the system recognize where
the decimal point should be during sliding.
here is a sample of my shifter code:
entity ShifterSample is
    Port ( clk : in  std_logic;
           reset : in  std_logic;
           data_i : in  std_logic_vector (31 downto 0);
           data_o : out  std_logic_vector (31 downto 0));
end ShifterSample ;
architecture Behavioral of ShifterSample  is
signal dataout_sig : std_logic_vector (31 downto 0);
begin
process (clk, reset, data_i, dataout_sig)
  begin
  if (reset = '1') then
    dataout_sig <= "00010010001101000101011001111000";
    --elsif (load ='1') then
  dataout_sig<=data_i;
  elsif (clk'event and clk = '1') then
    dataout_sig <= dataout_sig(27 downto 0) & dataout_sig(31 downto 28);
    end if ;
    end process;
data_o<=dataout_sig;
data_o<=data_o(27 downto 0) & data_o(31 downto 28);
end Behavioral;
Also how would I link this in my main file:
entity time_multiplexer_main is
  Port(clk : in std_logic;
     data_in : in std_logic_vector(7 downto 0);
       seg : out std_logic_vector(6 downto 0);
       anode : inout std_logic_vector(3 downto 0));
end time_multiplexer_main;
architecture Behavioral of time_multiplexer_main is
component frequency_divider
  port( clk: in std_logic;
      reset: in std_logic;
      clock1: inout std_logic);
end component;
component time_multiplexer_4digit
port(clk : in std_logic; --multiplexing clock(1 kHz)
       reset : in std_logic; -- reset signal
     display_value : in std_logic_vector(15 downto 0); --BCD digits to
be displayed
       seg : out std_logic_vector(6 downto 0); --7 cathodes
end component;
signal clk_1kHz: std_logic;-- this is a signal connecting the frequency
divider to the time multiplexer
--signal dataout_sig:
begin
cop1: frequency_divider
    port map( clk=>clk,
      reset=>reset,
       clock1=>clk_1kHz);
cop3: time_multiplexer_4digit
  port map( clk=>clk_1kHz,
        reset=>reset,
        DISPLAY_VALUE=>"0001001000110100",-- DISPLAY value signal
        seg=>seg,
        anode=>anode);
end Behavioral;
  • [vhdl]VHDL-Code[/vhdl]
