Peltier Element, Cooling, Freezing
Guest #5167833
Hey Guys,
I want to build a cooler for alcoholic drinks like Jägermeister or such
things. I tried to rebuild a Jägermeister Tap machine. If you dont know
what i mean, here is a picture of this machine:
https://i.pinimg.com/736x/cb/86/c7/cb86c708abe2e89c129d209233839231--contests-canada-jagermeister.jpg
They bring the Jägermeister down to a temprature of about -15°C oder
even cooler.
So I just tried to use a alluminium Case ( Volume about 0.4 liter),
isolatet it against the temprature around and cooled the hole case with
jägermeister in it, with a Peltier Element (TEC 12712 TEC1- 12712). The
other Side of the Peltier was connectet to a water cooling system. But
sadly the tempreture inside the Case only reached about minus -3°C
I hope you guys can help me to get the system better.
the picture shows the Project right now, the gren tubes are used as
In-/output of the jägermeister in/out of the Case. The microcontrollers
are not important. The Trafo is a 12V 15V trafo an directly contacted to
the peltier element.
This topic is locked and can not be replied to.
