signales in processes VHDL
Guest #5166516
1 entity klausurCircuit is
2 end klausurCircuit;
4 architecture behavior of klausurCircuit is
5 signal a,b,c,d,e,f : bit;
6 begin
8 process (a,b)
9 begin
10 c <= not (a and b) after 6 ns;
11 d <= not (b or c) after 5 ns;
12 end process;
14 process (a,c)
15 begin
16 e <= transport c xor a after 5 ns;
17 end process;
19 end architecture behavior;
what I don't understand is when you have in process(a,b) two signales
what does that mean, when will the d change. Is what I made correct.
Thank you for the explanation, I am new to Vhdl just trying to
understand how it works.
Best Regards
Guest #5180624
I think this is the inner meaning of this "Klausur". you will have to
find out, when the signals operate and when not.
Moderator (Company: Titel) #5180736
Oussama wrote:
> 8 process (a,b)
> 9 begin
> 12 end process;
Just as a hint: this process has an incomplete sensitivity list. 'c' is
missing. So the solution is fairly tricky, because c changes 6ns after a
or b has changed. But because c is missing in the sensitivity list the
process is not evaluated again and d does not change.
I recommend to ask your teacher about that sensitivity list...
For the signal e you should calculate a xor-signal e' without delay. And
then simply shift that e' for 5ns.
Guest #5180924
Maybe this is intended since sampling is exactely simulated this way:
The result is taken over only the point of time when the gated clock
becomes active.
Guest #5182610
process (a,b)
is a method to describe a gate because c is progressed into d only when
b is active so any changes of c at others poits of time are not
relevant.
this way also clocks are simulated finally by converting the rising edge
command into a signal which is active for one simulation step only
Moderator (Company: Titel) #5182687
Klakx wrote:
> .. bad design practice
Because simulation result will not be the same like the behaviour of the
synthesized design.
So this "cute insider trick" is ugly coding no one will understand a
half year later. Even the coder himself. If this kind of coding is
teached anywhere then the school and the teacher is not worth the money!
I strongly recommend...
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
