How to combine bitstreams (thrid party IP cores) to use it in main design?
Moderator (Company: Titel) #5166372
• ▲ useful
▼ not useful
Jaodat wrote:
> I assume they provide the IP core in a form of bitstream file.
What does this assumption base on?
Then it is nearly useless because a bitstream is a programming file, its
only useful to be loaded directly into exactly one type of FPGA.
Usually a core consists of several (encrypted) netlist files and a HDL
wrapper to invoke it in your top level design.
> My question is how we actually combine these different bitstreams from
> different vendors and configure it in our system?
You know the different processing steps of your (unknwon) systen?
Synthesize ... Translate ... Place&Route ... Programfile Generation?
If no: read the manual.
If yes: the wrapper goes to the synthesizer, the netlist usually to P&R.
Guest #5167018
• ▲ useful
▼ not useful
For Xilinx and Lattice FPGA you would typically receive a NGO black box
object file with the interface defined in the wrapper source that Lothar
already mentioned. Then there's not much difference from using a source
or black box component, from the programmer's perspective. Just that you
can't stick the NGO into simulation.
  • [vhdl]VHDL-Code[/vhdl]
