Forum: FPGA, VHDL & Verilog Post-synthesis simulation, Quartus and Modelsim-Altera
von Reza M. S. (Company: SBU) (shahshahani86)
Dear all
I have synthesized my VHDL-coded design in Quartus v17 and have the
netlist (vho) file. But the problem is that after synthesis, my design
data ports in the resulting netlist file has changed from signed to
std_logic_vector. What's the problem? How can I resolve this issue?
Thanks
Reza
Don't do a Post-Whatever-Simulation. It's useless. Perform a behavioural
simulation and use proper constraints. That's all you need.
Use std_logic in your ports. To use std_logic in ports is an unofficial
industry standard.
von Michael W. (Guest)
Why should be be useless?
A counterquestion: what should it be good for?
Do a behavioural simulation AND add proper constraints to the design,
that's enough.
Why do you think, Xilinx took effort in integrating this function into
their design tools?
The main idea behind this to compare various types of placement options
and verify them. Of course this is done during automatic place and route
when using timing driven placement and it works whenever the placer is
intelligent enough to find a solutiuon.
But as soon as a mixture of area and speed is required, this is all a
matter of probabiliy how good it works. Also temperature issues do
apply. During auto placement, the placer has to be pessimistic and stays
far away from the possible desitiy and timing for those parts of the
cirtuic which do not toggle permanently and stay cool enough.
Third party tools make use of that netlist to resynthesize this.
Also when you try to manipulate the FPGA with the FPGA editor on low
level, you need this timing simulation.
> their design tools?
Because users with design strategies from the last millennium wanted
them to.
> and verify them.
Thats of no interest when the design is reported as "fast enough". The
only timing analysis one must do is the STA (static timing analysis).
Why sould I dig around in the FPGAs layout at all? When this is the only
way, then its the wrong way leading to a dead-end.
Even with an "working" timing simulation there is not the slightest
guarantee that you will find all the possible timing violations. Because
you must no only run a "worst case simulation" and a "best case
simulation". No you will have to run a "random timing simulation" also
because thats what will happen in real life.
So for me the summary is:
In 99.99% of the designs you only need the STA together with correct
constraints. When you are one of the 0.01% then an FPGA may be the wrong
thing for the job.
von Amol Amol (Guest)
In a processor based architecture, post synth can be useful
Esp if there is ROM ( or RAM as well in some cases) that is to be
tested.
Idea is to ensure that initialisation values were integrated correctly
for those memory instances and processor is able o fetch/perform action.
If there is any indication that drives IO based on those initialisation
values from HEX file, then post synth simulation can help for better
confidence.
Thanks,
Amol
von Erik (Guest)
Post-Layout simulation is the only way to detect dynamical timing
problems, caused by complex clocking or when non-hazard free logic has
been implemented on interfaces to hard-macros.
A static timing analysis will not help in such cases.
