Easy way to use LEDR to show the duplicate numbers?
OP #5157632
I am working for a simple slot machine by using VHDL, the specifition
let me to show the duplicate numbers which is the result of the spin. It
could be many duplicates of the same number or different numbers have
appeared at least twice.
For example,
if the number is 278551 then there are two 5 to lit two LEDR
if the number is 578551 then there are three 5 to lit three LEDR
if the number is 278558 then there are two 5 and two 8 to lit four LEDR
if the number is 578558 then there are three 5 and two 8 to lit five
LEDR
if the number is 585885 then there are three 5 and three 8 to lit six
LEDR
if the number is 777777 then there are six 7 to lit six LEDR
So is there any simple way to implement this function? I was trying to
use FSM but it looks to complicated.
Needs some help :)
Moderator (Company: Titel) #5157729
James D. wrote:
> I was trying to use FSM but it looks to complicated.
Of course you will need some kind of FSM. Just keep in mind: each simple
counter is a FSM. And you need at least 6 counters counting randomly and
independently from 0 to 9 for your 6 digit "number".
Or do you only have 1 counter counting from 000000 to 999999? That would
not look very "slotmachinelike"...
For a slot machine the top FSM ist the one that handles the slot machine
itself: waiting for the start button, spinning the "wheels", evaluating
the result. Your "evaluation" FSM will have to go thru the digits and
compare them.
All in all its a fairly easy job to be done. But first you need a
strategy HOW to find doubles/multiples in the "wheels".
> Needs some help :)
Just show what you have, then we can discuss about how to go further on.
> if the number is
What about 234234?
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
