Counter in the existing program
OP (Company: Mindteck) #5144105
hi,
i have a vhdl code written below,
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
  entity powerseq is
  port(      fpga_clk: in std_logic;
          EN_1v  : out std_logic;    -- Enabling signal of 1V
          EN_1v8  : out std_logic;  -- Enabling signal of 1V8
          EN_1v2 : out std_logic;    -- Enabling signal of 1V2
          EN_1v35 : out std_logic;  -- Enabling signal of 1V35
          EN_2v5 : out std_logic;    -- Enabling signal of 2V5
          EN_3v3 : out std_logic;    -- Enabling signal of 3V3
          EN_V1P0 : out std_logic;  -- Enabling signal of V1P0
          PGOOD_1v8 : in std_logic:= '1';   -- Power Good Signal 1V8
          PGOOD_1v35 : in std_logic:= '1';  -- Power Good Signal 1V35
          PGOOD_2v5 : in std_logic:= '1';  -- Power Good Signal 2V5
          PGOOD_3v3 : in std_logic:= '1';  -- Power Good Signal 3V3
          PGOOD_1v  : in std_logic:= '1';  -- Power Good Signal 1V
          PGOOD_1v2 : in std_logic:= '1';  -- Power Good Signal 1V2
          poreset_b  : out std_logic;
          PGOOD_V1P0 : in std_logic:= '1'  -- Power Good Signal V1P0
 end powerseq;
 architecture behav of powerseq is
 signal pon_state : integer := 0;
 signal counter : integer := 0;
 begin
  process(fpga_clk)
30
    begin
31
32
      if(rising_edge(fpga_clk)) then
33
        if(pon_state = 0) then
34
            poreset_b  <= '1';
35
            EN_1v8  <= '1';
36
            EN_1v35 <= '1';
37
            EN_2v5  <= '1';
38
            EN_3v3  <= '1';
39
            pon_state <= 1;
40
            EN_1v <= '0';
41
            EN_V1P0 <= '0';
42
            En_1v2<= '0';
43
        end if;
44
        if(pon_state =  1) then
45
          if((PGOOD_1v8 and PGOOD_1v35 and PGOOD_2v5 and PGOOD_3v3 )='1') then --checking whether the PGOOD signals are stable
46
            EN_1v <= '1';
47
            EN_V1P0 <= '1';
48
            poreset_b<= '0';
49
            pon_state <= 2;
50
          end if;
51
          if (pon_state = 2) then
52
            if((PGOOD_1v and PGOOD_V1P0)= '1') then --checking whether the PGOOD signals are stable.
53
            En_1v2<= '1';
54
            pon_state <= 3;
55
          end if;
56
          end if;
57
      end if;
58
    end process;
59
  end behav;
in the above code how i can add 2 sec delay before checking the
.I have assigned all the signals to leds. and need to see the delay in
the output leds.
Moderator (Company: Titel)
Never use the obsolete std_logic_arith and its std_logic_(un)signed
together with the numeric_std. You will get strange behaviour and error
messages due to double type definitions.
Hareesh M. wrote:
> actually by adding a counter will solve this problem right?
Yes, allmost all times in FPGA are realized by counters...
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
