watch #define constant expression in debug
Guest #5126946
Hello guys,
i came about a something strange to me while programming and Debugging
some c-Code with AVR-Studio 7. I was trying to watch the value of an
Expression while Debugging, but i get the message "unknown identifier".
The Expression is defined as follows:
#define THRESH1 (uint16_t) ((uint32_t)1024*(500 + 1*800)/5000)
does anyone has an idea, why i can't watch the value of this constant?
By the way, i've tried declaring it localy or global, but i still get
the same message. Moreover, i tried with the following Expression:
const uint16_t thresh1_3 = (uint16_t) ((uint32_t)1024*(500 +
3*800)/5000);
but the watch variable only works when it is a local constant, not
global. Does anyone has a hint there too? I also deactivated
optimizations too but it doesn't seem to help. Thanks and Cheers
Paul
Guest #5130863
Paul wrote:
> Hello guys,
Because it is a preprocessor macro. At runtime, it doesn't exist in that
form anymore. A macro is similar to your editors search/replace
functions, just with the difference that the text to be replaced is
specified within the processed file itself.
> the same message.
There is no such thing as "locally" or "gobally" with respect to macros.
> 3*800)/5000);
> global.
It might get optimized out by the compiler. Does the symbol thresh1_3
exist in the generated executable?
#5132118
Thank you, that is what i tought too, anyways I want to use the
calculated constant to test for a certain condition. So I expected I
could actually see what value was calculated:
#define THRESH1_1 (uint16_t) ((uint32_t)1024*(500 + 1*800)/5000)
#define THRESH1_2 (uint16_t) ((uint32_t)1024*(500 + 2*800)/5000)
#define THRESH1_3 (uint16_t) ((uint32_t)1024*(500 + 3*800)/5000)
#define THRESH1_4 (uint16_t) ((uint32_t)1024*(500 + 4*800)/5000)
if(u16_adValue0 <= THRESH1_1)
... something;
else if(u16_adValue0 <= THRESH1_2)
... some other thing;
and so on...
I did deactivate optimizations, but it didn't Change anything. I don't
really understand what you mean with generated executable because i'm
flashing the Code directly in a microcontroller (ATmega32u4)
Guest #5132132
If your macro is expected to represent just a numerical expression
(macros could actually represent anything) then you could directly
assign it to a variable for debugging purposes. If you make that
variable volatile then it won't be optimized away and you can watch it
in the debugger to confirm that your macro expands and evaluates to the
correct value.
#define FOO_BAR  (uint16_t) ((uint32_t)1024*(500 + 1*800)/5000)
// fixme: remove this after you know its evaluated correctly
volatile uint16_t debug_foo_bar = FOO_BAR;
Start a new thread
