Which controller to choose as a newbee? Arduino?
Guest #5124320
Hi there,
I am mechnical engineer with very limited knowledge about programming
and electronics at this stage.
For now I would like a controller to read a couple of temperatures (4x;
-30 - 70°C) and voltages (4x; 4 - 90V), to display them on a screen and
switch on and off loads depending on the programming.
What's the easiest way to start? Is there a ready-made fan-less box with
Arduino and display available?
Thank you guys for some pointers.
Guest #5124837
Hello Joe,
i would recommend you to do steps:
1) get an Arduino and an RS232 or I2C display (like 4x20) and print
"hello world" on it
2) get i2c thermomenter ICs fitting for your temp range and get
temperature values, plus print it on the display.
3) Learn how use the A/D converters by using a potentiometer of lets say
10kOhm and an analog input. Then develop a transition hardware that
brings your voltage to 0-5V DC - that is what the Arduino can measure.
Make sure the output never gets over this values to not destroy the
Ardino / inputs.
4) Learn how to switch a pin on and off :-) Then develop some drivers
for your load switchable by 0V/5V /Pin output) that does not load the
switching pin with more than 20mA.
finally: If you are less experienced, try to go step by step. If you
fail in the first step, or get unpatient - no need to spend time and
money for the other steps ;-)
#5125456
Thanks!!
That sounds like the hard (and proper) way to really learn about
electronics. :)
I was looking for a quick and dirty solution to solve my current needs.
Something out of the box!? I think my problem and requirements are not
too special. I would guess there are plenty of similar solutions around
already.
My idea was, with the problem solved there is a good chance I feel I
want to dive deeper later on (going through the steps described). If
not, at least the problem is solved. :D
Guest #5125506
You have 3 options how your project will be:
Quick, cheap and good.
Now please choose any two.
Of course there are ready - made solutions: search for temperature
switches. But that will not satisfy you i guess because it is not
exactly what you want.
Guest #5125508
Cutted from Wikipedia: "Arduino .. aiming to provide a low-cost and easy
way for novices and professionals to create devices that interact with
their environment using sensors and actuators."
I have a good knowledge in electronic hardware, but because of simple
programming and low prices from China I like Arduino!
There are a lot of scripts and samples in the internet, however, as good
advice (Guest) wrote, you have to spend time about and to work step by
step.
Maybe, I don't know about. As a mechnical engineer you should be able or
have contacts to build your own housing.
Guest #5125784
If you are planning to create more, similar projects in the future – and
want to have a certain degree of flexibility, Arduino might be the
simplest way to go. It might not be the most professional and it also
might not be the cheapest possible. But the price tag is adequate, the
support is outstanding, and because it is mostly based on the well
established Atmel processor family, you can, in the future, design your
own, professionally looking boards without the pre-made Arduino breakout
boards.
It also features a wide band of libraries, so connecting peripherals
like LCDs, sensors, motors and so on should be as simple as possible.
Most of the time, you don't need to worry about setting individual pins
or precise timing. There are very abstracted commands that are as simple
as Display.init(ENTER, PIN, NUMBERS, HERE); and Display.print("Your text
goes here"); You should even get that with the most rudimentary
programming skills.
But if this is a one-time shot, I highly doubt that it would be really
worth the time you have to spend. Even for me, as a professional
software developer, it took a few days to really got my first project
running as expected, for example.
#5127762
That's some great advice.
I'm aiming for quick and cheap. 200€ investment into a chance to learn
something is okay for me.
I think I would use Virtuino via Bluetooth as a display. Looks like it
serves as a great input device as well.
Is there a certain Arduino board that you would recomment over others?
Guest #5128500
If the price tag is not that important, I would always go for a MEGA as
development platform. This gives you the most possibilities. If you want
to implement your project on an actual board later on, you can easily
port your program to a Uno or Tiny.
Guest #5129002
André R. wrote:
> I would always go for a MEGA as development platform.
Please remember:
So in this state, I would recommend to start with Arduino-Uno as I did
by myself because most tutorials and scripts in the internet are based
on Uno.
Later, after the basics were in, I moved to other versions - my favor is
the Nano.
And for saving ports, my displays I run with I2C interface, from the
Chinese less than 1 €uro.
#5135578
I will be tinkering with solar and are excited about getting stuff off
the grid.
I am considering two more requirements for the board:
- low power consumption
- varying input voltage shouldn't be an issue.
7 or 9V are a bit odd.
I see some boards support 5V or even a range of 4-16V input.
Unfortunately, they are neither Uno nor Mega.
At some point I will want to involve my ebike batteries (up to 84V) and
at least measure (monitor) their voltage.
Start a new thread
