VHDL Code error
OP (Company: Mindteck) #5123811
hi,
i have an if statement in my code
if(a and (not b) and c = '1') then
          output <= '1';
      else
           output <= '0';
       end if;
a, b, and c are internal signal of type std_logic;
output is signal out std_logic;
when compile this code it is showing an error
Error (10476): VHDL error at PowerSeq1.vhd(486): type of identifier "a"
does not agree with its usage as "boolean" type
Guest #5123829
Hareesh M. wrote:
> if (a and (not b) and c = '1') then
                              |_ type: boolean
the and operator needs operands of the same type, i.e all operands are
boolean, or all of type std_logic.
The comparsion "c = '1'" results into type boolean; the sub-term "a and
(not b)" into type std_logic (because a and b are of type std_logic)->
the rightmost "and" faces type missmatch.
Moderator (Company: Titel) #5124632
Hareesh M. wrote:
> it is solved
> if((a and (not b) and c) ='1' ) then
I would prefer this:
if (a='1' and b='0' and c='1') then
Because there it is absolutely obvoius to see whats wanted without doing
any logical calculations and digging around with the (not b) together
with the ='1'...
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
