FPGA VS CPU Comparaison
Guest #5120310
Hello,
I have some question to compare FPGA vs CPU:
1- FPGA consume power more than CPU ?
2- FPGA is always more faster than CPU what ever the fuctions to
execute?
3- developpement with FPGA  is more expensive than developpement CPU ?
4- developpement with FPGA is hard to maintain than developpement CPU ?
5- developpement with FPGA is hard to produce than developpement CPU ?
Thanks a lot :)
Guest #5120314
Abdeljalil wrote:
> Hello,
> execute?
> Thanks a lot :)
1 - No or yes
2 - No or yes
3 - No or yes
4 - No or yes
5 - No or yes
Your question(s) is as specific as when I write: C is better than VHDL.
Nobody can answer this question. So
42
Moderator (Company: Titel) #5120332
Whats the background to this questions?
What FPGA do you have in focus?
What CPU?
What job has to be solved?
Until at least those parameter are not clearly specified ui is
completely right.
Guest #5120460
I m a student ... i prepare an exam and i have this question
we have a CPU RISC and a FPGA  .. the both execute the same function
Thanks
Moderator (Company: Titel) #5120481
I cannot see any question there...
What function?
So, let's try it that way: you guess an answer and we discuss it.
Guest #5120518
As the previous authors already said, there's no direct 1:1 comparison
possible (and for sure not in the generality as asked by you), because
it's two completely different pieces of hardware, or should I rather say
two completely different approaches.
Whilst an FPGA is basically only a huge field of transistors which can
be connected programmatically such that they comprise almost all logical
functions conceivable (I. e. those functions can - and mostly do - run
in parallel), a CPU is a processor which executes algorithmic commands
instruction per instruction (I. e. fully successive operation (at least
in the classic, coursebook sense - of course nowadays there's much more
sophisticated mechanisms included at least in all PC CPUs).
Would propose for you to refer to Wikipedia in order to gain a basic
understanding of the working principles:
https://en.wikipedia.org/wiki/FPGA
https://en.wikipedia.org/wiki/CPU
Guest #5120824
This FPGA promotion "inadvertently" gives the explanation:
FPGA can implement parallel structures and be faster, but at the price
of more gates and more power consumption.
CPU can implement same calculation in a short program in tiny memory,
and use much less power, but slower. However if CPU has multiple cores
with SIMD then it can be as fast as FPGA and still low power.
https://www.xilinx.com/products/technology/dsp.html
Worst example we had: Some fuzzy control algorithm fitting nicely into
tiny 8051 exceeded huge FPGA with 100k gates.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
