Internal signals in vhdl
Moderator (Company: Titel)
Hareesh M. wrote:
> How do i access the internal signals in the top module to testbench
> program.
Wht do you mean with "access"? Just to view the signals? Or to force
them to a desired state?
And most important: What simulator do you use?
> The change in internal signals causes main signals to change.
Indeed thats usually the desired behaviour of almost every HDL design.
OP (Company: Mindteck)
Lothar M. wrote:
>> program.
i want to force them to a desired state, and forcing them causes the
changes in other signals too. Currently i'm using modelsim simulator.
Hareesh M. wrote:
> Lothar M. wrote:
>>> program.
i'm writing the main code and testbench for the same
  library ieee;
  use ieee.std_logic_1164.all;
    package vhdl_pkg is
      constant HOTS_WAP:   std_logic_vector(2 downto 0):= "111";
    end vhdl_pkg;
  library ieee;
  use ieee.numeric_std.all;
  use ieee.std_logic_unsigned.all;
  library work;
  use work.vhdl_pkg.all;
  Entity hotswap is
    port(ifc_clk: in std_logic;
        BD_SEL_PLD: in std_logic:= '1';
        HS_PG00D_PLD:in std_logic:= '1';
        HS_FLT_PLD: in std_logic:= '1';
        ifc_ad0_7: inout std_logic_vector(2 downto 0);
        ifc_cs3_n: in std_logic;
        ifc_oe_n: in std_logic;
        ifc_we_n: in std_logic;
        ifc_a27_31: in std_logic_vector(2 downto 0)
  end hotswap;
  Architecture mpu of hotswap is
    signal ifc_dout:   std_logic_vector(2 downto 0);
    signal cpld_cs:   std_logic;
30
    signal cpld_oe:   std_logic;
31
    signal cpld_we:  std_logic;
32
    signal flt_reg:   std_logic;
33
    signal hotswap_pgood : std_logic;
34
    signal bd_sel_pld_reg : std_logic;
35
    signal pon_rst_n:  std_logic;
36
  begin
37
    process(ifc_clk)
38
    begin
39
      if(rising_edge(ifc_clk)) then
40
        if(pon_rst_n = '1') then
41
          cpld_cs <= '0';
42
          cpld_oe <= '0';
43
        else
44
          cpld_cs <= ifc_cs3_n;
45
          cpld_oe <= ifc_cs3_n and ifc_oe_n;
46
          cpld_we <= ifc_cs3_n and ifc_we_n;
47
        end if;
48
      end if;
49
    end process;
50
51
    process(ifc_clk)
52
      begin
53
      if((cpld_cs and cpld_oe)= '1') then
54
        case ifc_a27_31 is
55
          when HOTS_WAP =>
56
            ifc_dout(0) <= HS_FLT_PLD;
57
            ifc_dout(1) <= BD_SEL_PLD;
58
            ifc_dout(2) <= HS_PG00D_PLD;
59
          when others =>
60
            ifc_dout <= "000";
61
        end case;
62
      end if;
63
     end process;
64
     ifc_ad0_7 (0) <= ifc_dout(0);
65
     ifc_ad0_7 (1) <= ifc_dout(1);
66
     ifc_ad0_7 (2) <= ifc_dout(2);
67
  end mpu;
and the testbench is
library ieee;
entity hot_swap is
end entity ;
architecture hotswapping of hot_swap is
 component hotswap
  port( ifc_clk:   in std_logic;
        HS_PG00D_PLD: in std_logic:= '1';
 end component;
  signal  ifc_clk:    std_logic;
  signal  BD_SEL_PLD:  std_logic:= '1';
  signal  HS_PG00D_PLD: std_logic:= '1';
  signal  HS_FLT_PLD:  std_logic:= '1';
  signal  ifc_ad0_7:   std_logic_vector(2 downto 0);
  signal  ifc_cs3_n:   std_logic;
  signal  ifc_oe_n:    std_logic;
  signal  ifc_we_n:    std_logic;
  signal  ifc_a27_31:  std_logic_vector(2 downto 0);
  constant time_tb:   time:= 10 ms;
signal pon_rst_n : std_logic;
begin
30
  uut: hotswap port map(
31
32
  ifc_clk => ifc_clk,
33
  BD_SEL_PLD =>  BD_SEL_PLD,
34
  HS_PG00D_PLD => HS_PG00D_PLD,
35
  HS_FLT_PLD  => HS_PG00D_PLD,
36
  ifc_cs3_n =>  ifc_cs3_n,
37
  ifc_oe_n  =>  ifc_oe_n,
38
  ifc_we_n  => ifc_oe_n,
39
  ifc_a27_31 =>  ifc_a27_31);
40
clk: process
41
  begin
42
    ifc_clk <= '1';
43
    wait for time_tb/2;
44
    ifc_clk <= '0';
45
    wait for time_tb/2;
46
     end process;
47
stimlus: process
48
  begin
49
  wait for 5 ms;
50
  pon_rst_n <= '0';
51
  wait for 5 ms;
52
  pon_rst_n <= '1';
53
  wait for 5 ms;
54
  ifc_a27_31 <= "111";
55
  wait;
56
       end process;
57
end;
Usually you do NOT force an internal signal because you will not be able
to do that in a real design. So apply the stimuli data (inputs) in a way
you get the desired internal signals.
A few words to that design:
At all the simulation of this code will not match the reality due to a
wrong and incomplete sensitivity list. Here in simulation it will look
like the process depends on the clock, but in real life it is only a
completely combinatorial process:
    process(ifc_clk)
      begin
        case ifc_a27_31 is
          when HOTS_WAP =>
          when others =>
            ifc_dout <= "000";
        end case;
      end if;
     end process;
And much more worse: you implement a latch here.
That is 1. not necessary, 2. not desired and 3. no good design practice.
I suggest to write it without any process (using the concatenate
operator '&') this way:
      ifc_dout <= HS_PG00D_PLD & BD_SEL_PLD & HS_FLT_PLD when
                        cpld_cs='1' and cpld_oe='1' and ifc_a27_31=HOTS_WAP
                  else "000";
And one word to that here:
Thats not a fine trick. Write it this way, it is "more usual" and better
readable:
if (cpld_cs='1' and cpld_oe='1') then
If you want you can skip the parenthesis also:
if cpld_cs='1' and cpld_oe='1' then
BTW: Pls use the [vhdl] tokens around VHDL code (as described above
every text edit box).
thanks for your suggestion. Actually the values of HS_PG00D_PLD,
BD_SEL_PLD and HS_FLT_PLD might change while execution.The width of
ifc_dout is 7, for simulation i made it 3. That's why i wrote like that.
And i'll change the line as per your suggestion if((cpld_cs and
cpld_oe)= '1') then.
and what about the testbench?
Hareesh M. wrote:
> Actually the values of HS_PG00D_PLD, BD_SEL_PLD and HS_FLT_PLD might
Then those signals must be in the sensitivity list!
If you want to march on with the process, then this is the correct
sensitivity list:
    process(HS_PG00D_PLD, BD_SEL_PLD, HS_FLT_PLD, cpld_cs, cpld_oe, ifc_a27_31)
      begin
        case ifc_a27_31 is
          when HOTS_WAP =>
          when others =>
            ifc_dout <= "000";
        end case;
      end if;
     end process;
You already startet stimuli generation. Just go on with all the possible
states:
stimlus: process
  begin
  wait for 5 ms;
  pon_rst_n <= '0';
  wait for 5 ms;
  pon_rst_n <= '1';
  wait for 5 ms;
  ifc_ad0_7    <= "ZZZ";
  BD_SEL_PLD   <=  '1';
  HS_PG00D_PLD <=  '0';
  HS_FLT_PLD   <=  '0';
  ifc_cs3_n    <=  '0'; -- low active
  ifc_oe_n     <=  '0'; -- low active
  ifc_we_n     <=  '0'; -- low active
  wait for 1 us;
  assert ifc_ad0_7="100" report "Read not correct!" severity failure;
  wait for 1 us;
  ifc_ad0_7    <= "ZZZ";
  BD_SEL_PLD   <=  '1';
  HS_PG00D_PLD <=  '1';
  HS_FLT_PLD   <=  '0';
  wait for 1 us;
30
  assert ifc_ad0_7="110" report "Read not correct!" severity failure;
31
  wait for 1 us;
32
33
  -- and so on
34
35
  wait;
36
end process;
BTW1:
obviously all of your select signals are low active due to the _n at the
end of their names. Therefore this is rubbish:
          cpld_cs <= ifc_cs3_n;              -- low active --> high active??
          cpld_oe <= ifc_cs3_n and ifc_oe_n; -- cpld_oe is low active!
          cpld_we <= ifc_cs3_n and ifc_we_n; -- cpld_we also!
But at all this complete "control signal process" is not necessary at
all. Instead it is leading to a kind of clocked bus handling. But that
you will find out in simulation further on.
A hint: you MUST set the inout bus to HiZ when you don't use it for
output!
BTW2:
That looks very, very confusing to me:
Must it be ifc_ad2_0 instead?
(Company: Toshiba)
Hi...i am a new user here.As per my knowledge you do NOT force an
internal signal because you will not be able. To do that in a real
design. So apply the stimuli data in a way you get the desired internal
signals.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
