VHDL instantiation in modelSim
OP (Company: Mindteck) #5106301
Hi i have written a vhdl code along with the testbench..when i simulate
it in the modelSim i don't get an expected result
The VHDL Code is given below
 Library ieee;
    use ieee.std_logic_1164.all;
    entity PowerSeq is
        port(fpga_clk: in std_logic;
                Enable_Bias_1V, Enable_3V3, Enable_1P5V, Enable_1V: out
std_logic;
                PG_3V3: in std_logic);
    end PowerSeq;
    architecture MPU_PowerSeq of PowerSeq is
        signal pon_state: integer:= 0;
    begin
        process(fpga_clk)
        begin
            if(rising_edge(fpga_clk)) then
                if(pon_state = 0) then
                    Enable_3V3 <= '1';
                    Enable_1P5V <= '1';
                    Enable_1V <= '0';
                    Enable_Bias_1V <= '1';
                    pon_state <= 1;
                end if;
                    if(pon_state = 1) then
                        if(PG_3V3 = '1') then
                            Enable_1V <= '1';
                        end if;
                    end if;
                end if;
            end process;
    end MPU_PowerSeq;
 and the Test bench is also given below
  library ieee;
 use ieee.numeric_std.all;
 use ieee.std_logic_unsigned.all;
 entity PowerSeq is
 end PowerSeq;
 component Sequence is
    port(fpga_clk : in std_logic;
        Reset: in std_logic;
std_logic;
    end component;
 signal  Reset: std_logic:= '0';
 signal  fpga_clk : std_logic:= '0';
 signal  Enable_Bias_1V: std_logic:= '0';
 signal  Enable_3V3: std_logic:= '0';
 signal  Enable_1P5V: std_logic:= '0';
 signal  Enable_1V: std_logic:= '0';
 signal PG_3V3: std_logic:= '0';
 constant tb_time: time:= 15.5 ns;
 begin
 uut: sequence port map(
    Reset => Reset,
    fpga_clk => fpga_clk,
    Enable_Bias_1V => Enable_Bias_1V,
    Enable_3V3 => Enable_3V3,
    Enable_1P5V => Enable_1P5V,
    Enable_1V => Enable_1V,
    PG_3V3 => PG_3V3
 stimlus: process
 begin
    fpga_clk <= '0' after tb_time, '1' after 2 * tb_time;
    wait for 2 * tb_time;
 end process;
 tb: process
 begin
  wait for 50 ns ;
  Reset <= '0';
  Enable_3V3 <= '0';
  Enable_3V3 <= '0';
  Enable_1V <= '0';
  wait for 50 ns;
  Reset <= '1';
  wait for 1 us;
  end process;
end;
Guest
Nothing. Testbench has nothing todo with synthesiser.
Again, what is not working in your simulation?
maybe you are fooled by your resets etc?
tb: process
 begin
  wait for 50 ns ;
  Reset <= '0';
  Enable_3V3 <= '0';
  Enable_3V3 <= '0';
  Enable_1V <= '0';
  wait for 50 ns;
  Reset <= '1';
  wait for 1 us;
  end process;
tb: process
 begin
  wait for 50 ns ;
  Reset <= '0';
  Enable_3V3 <= '0';
  Enable_3V3 <= '0';
  Enable_1V <= '0';
  wait for 50 ns;
  Reset <= '1';
  wait; -- STOP THIS PROCESS HERE?
  end process;
I have changed the above testbench.
library ieee;
entity PowerSeq is
end PowerSeq;
       Reset         : in std_logic;
std_logic;
       PG_3V3        : in std_logic
  end component;
    signal   Reset          : std_logic:= '0';
    signal   Enable_Bias_1V : std_logic:= '0';
    signal   Enable_3V3     : std_logic:= '0';
    signal   Enable_1P5V    : std_logic:= '0';
    signal   Enable_1V      : std_logic:= '0';
    signal   pon_state      : integer:= 0;
    signal   PG_3V3         : std_logic:= '0';
    constant tb_time        : time:= 1 ns;
begin
  Reset => Reset,
  PG_3V3 => PG_3V3
stimlus: process
begin
end process;
tb: process
    begin
    wait for 5 ns ;
    Reset <= '0';
    Enable_3V3 <= '1';
    Enable_1P5V <= '1';
    wait for 5 ns;
    Enable_3V3 <= '1';
    Enable_1P5V <= '1';
    pon_state <= 1;
    end if;
    PG_3V3 <= '1';
    Enable_1v <= '1';
    end if;
    -- wait for 5 ns;
    --Reset <= '1';
    end process;
end;
Guest
$ vlib work
$ vcom sequencer.vhd
Model Technology ModelSim SE-64 vcom 10.3d Compiler 2014.10 Oct  7 2014
-- Loading package STANDARD
-- Loading package TEXTIO
-- Loading package std_logic_1164
-- Compiling entity PowerSeq
-- Compiling architecture MPU_PowerSeq of PowerSeq
Errors: 0, Warnings: 0
$ vcom sequencer_tb.vhd
-- Loading package NUMERIC_STD
-- Loading package std_logic_arith
-- Loading package STD_LOGIC_UNSIGNED
###### sequencer_tb.vhd(8): component Sequence is
** Error: sequencer_tb.vhd(8): near "Sequence": expecting IDENTIFIER
Errors: 1, Warnings: 0
After fixing some identifiers errors.
Than I had to fix mismatched component/entity description and - maybe
this is the important thing - add additional delay after "if(pon_state =
0) then ... end if;" in your stimulus generation.
Take a look again for the concept of signals in VHDL.
See simulation results in the picture. I also attach the modified
testbench.
Duke
Guest
I am always impressed that people spend time on analyzizng other
people's code to find the syntax issues. Shouldn't it be a task to learn
to do that by one self?
BTW:  Duke, you seem to be using and old MOdelSIM with data 2014.
>"Model Technology ModelSim SE-64 vcom 10.3d Compiler 2014.10 Oct  7 2014"
Why is this?
Are you using an old dongle, too? :D :D :D
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
