Artificial Neural Network in FPGA
Moderator (Company: Titel)
Andrzej B. wrote:
> Is possible make ANN, especially deep learning in FPGA to parallelize net?
For sure. But you must be able to transfer your algorithms into the FPGA
in a way that they can be computed in parallel. And theres the crux:
usually you have so many data that you cannot do that computing in
parallel. So you must break it up it in serial calculations.
And there every cheap graphic controller beats a softcore implemented
inside a FPGA due to its broad and fast memory interface.
Guest
I would use Cuda. Much cheaper than anything else with FPGAs. The
problem is the parallel programming. Your algorithm needs to be
parallelized. If your problem can not be parallelized you won't ahieve
any improvements ...
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
