Solid State Relay and PCF8574
Guest #5093074
Hi all,
I've a Rasperry Pi that is connected to an 8-Bit IO-expander (PCF8574)
over I2C. The IO-expander should control a Solid State Relay Board from
SainSmart. The name of the Relays is "Omron G3MB-202P".
But when I connect the Relayboard to the IO-expander (pins configured
correctly as output) the pins will change to HIGH in the console and are
not controllable anymore until I disconnect the RelayBoard from the
IO-exapnder.
The setup works for me, when I connect a normal Relay board (like the
Board from SunFounder that is made for Arduino) to the IO-expander.
Thanks in advance,
Michael Mayerhofer
Guest #5093145
There is no special wiring.
I have a breakout board from Waveshare with the PCF8574 on it that is
directly connected to the relay board from Sainsmart. The RelayBoard
Power-in is wired to the RaspberryPi 5V.
The Power supply and I2C of the breakout board is also directly
connected to the RaspberryPi.
As I wrote above, this setup works perfectly with a normal RelayBoard.
Michael_mhr
Moderator (Company: Titel) #5093155
Anyway: electricians talk to other electricians by using schematics. So
just draw 2 schematics. One of the working configuration and one of the
faulty. Add as much information to those schematics. It will help you
further on...
Add information and/or a link to those boards also. There is more than 1
relay board availabe from sainsamrt. No one of those relay boards can be
directly connected to the IO expander. There must be done some wiring.
Maybe you can post a photo of that.
Guest #5093275
You can't configure a PCF8574 pin as output (there is no direction
register). Reading the data register just returns the pin state.
If you set the pin to LOW,  the chip will strongly pull down the line.
If you set the pin to HIGH, the chip will weakly   pull up   the line.
So if you output a LOW and you see a HIGH, then something is driving
against the PCF8574, and is stronger than that chip. This might already
have killed the PCF8574. Check your wiring for shorts.
Start a new thread
