constrain implementation
OP (Company: zeazeazea) #5068522
• ▲ useful
▼ not useful
Hello every one,
Here is a part of my code:
      when MC_BIT_AND =>        alu_out <= alu_in1 and alu_in2;
      when MC_BIT_OR =>         alu_out <= alu_in1 or  alu_in2;
      when MC_BIT_XOR =>        alu_out <= alu_in1 xor alu_in2;
      when MC_BIT_ASL =>        alu_out <= alu_in1(7 downto 0) & "0";
      when MC_BIT_LSR =>        alu_out <= alu_in1(0) & "0" & alu_in1(7 downto 1);
      when MC_BIT_ROL =>        alu_out <= alu_in1(7 downto 0) & c_flag;
      when MC_BIT_ROR =>        alu_out <= alu_in1(0) & c_flag & alu_in1(7 downto 1);
      when others =>            alu_out <= alu_in1;
I have to separate physicly all "when" banches of the code (it would be
a bit complex to explain why). I looked at xilinx constrains guide and I
have seen "keep hierarchy" constrain but it seems to work only for
entities.
Does anyone get an idea of what to do?
Thank you in advance
Moderator (Company: Titel) #5068535
• ▲ useful
▼ not useful
I didn't get the problem at all.
> (it would be a bit complex to explain why).
It would be very interesting why.
Especially why a obvious beginner needs such an advanced procedure...
You cannot do any "physics" like you want in VHDL code.
So, whats the actual problem?
OP (Company: zeazeazea) #5068564
• ▲ useful
▼ not useful
The reason why I need to use a such advanced procedure is that I'm
studiing coupling effect on low distance implementation. Even if you are
right, why are you saying I'm a beginner?
You says that we cannot do "physics" in VHDL nevertheless we can input
"physical constrains" according to xilinx documentation so I don't
understand.
"I didn't get the problem at all." , "So, whats the actual problem?"
I will do 2 measures and I need 2 different implementation, one with a
low distance between my all the posibilities of the "when" and one with
more important distance.
I know that I will have the same results in terms of input and output
but that's not the point, I measure power consumption.
Moderator (Company: Titel) #5068605
• ▲ useful
▼ not useful
Sophie T. wrote:
> Even if you are right, why are you saying I'm a beginner?
As you expect to be able to control such behaviour with a HDL
description. If you want to dig down deep in hardware, then you must
access the floorplanner
As I said: there is no "distance" with these "when", because there is no
"when" inside the FPGA. You will only find 4 or 6-input LUT which will
incoorporate the functionality you describe. The most important desire
of the toolchain is to keep the whole logic as compact and fast as
possible.
The only thing you can do is to separate those LUT involved in the logic
to get long distance lines between them. But there is no formula like "1
when = 1 LUT"...
Guest #5068640
• ▲ useful
▼ not useful
put every Statement in a seperate module like y <= alu_in1 and alu_in2
and y <= alu_in1 or alu_in2, and so on.
In your upper state module you link only the Outputs.
when MC_BIT_AND =>        alu_out <= y1;
when MC_BIT_OR =>         alu_out <= y2;
in your designflow you should floorplan your subcomponents afterwards.
  • [vhdl]VHDL-Code[/vhdl]
