ls.c:(.text+0x2dc): undefined reference to `S_ISSOCK'
OP (Company: no) #5066028
if(S_ISDIR(statbuf.st_mode))
             printf("d");
        else if(S_ISCHR(statbuf.st_mode))
            printf("c");
        else if(S_ISBLK(statbuf.st_mode))
            printf("b");
        else if(S_ISREG(statbuf.st_mode))
            printf("-");
        else if(S_ISFIFO(statbuf.st_mode))
            printf("f");
        else if(S_ISLNK(statbuf.st_mode))
            printf("l");
        else if(S_ISSOCK(statbuf.st_mode))
            printf("s");
I read the manual here
https://www.gnu.org/software/libc/manual/html_node/Testing-File-Type.html
This code after compilation produces this error, if I comment on the
line with this error, then the error disappears
#5066055
Peter II wrote:
> on a linker error a include do not help
sure it does.
An undefined preprocessor symbol ends up in linker errors.
The OP should have received meaningful compiler warnings much earlier
already, however (which he appears to ignore but shouldn't).
Guest #5069675
Kirkina A. wrote:
>> Compile with
>> -D_XOPEN_SOURCE=500
>> man 2 stat
>> should have shown you that.
> man 2 stat did not show it.
Seems this has been moved to a separate man page lately. On my linux
system, this is mentioned in man 2 stat, but the latest version of the
linux man page project
(http://man7.org/linux/man-pages/man2/stat.2.html) just says:
st_mode
              This field contains the file type and mode.  See inode(7) for
              further information.
and the inode man page says:
The definitions of most of the above file type test macros are
provided if any of the following feature test macros is defined:
_BSD_SOURCE (in glibc 2.19 and earlier), _SVID_SOURCE (in glibc 2.19
and earlier), or _DEFAULT_SOURCE (in glibc 2.20 and later).  In
addition, definitions of all of the above macros except S_IFSOCK and
S_ISSOCK() are provided if _XOPEN_SOURCE is defined.  The definition
of S_IFSOCK can also be exposed by defining _XOPEN_SOURCE with a
value of 500 or greater.
Start a new thread
