How to get current time in FPGA?
Guest #5065672
Sorry, but your question suggests that you haven't understood at all
what FPGAs are and what they actually do.
Python and Java are Programming Languages intended to be run on some
sort of computer with a dedicated computation unit and some software
environment already existing. This is why there is a time available
which can even be synchronized in some way (NTP, GPS, ...).
A FPGA is very different from that. It is basically just a buch of logic
components whose wiring can be described by a special hardware
description language (HDL), like VHDL or Verilog. These logic components
basically have no clue about time. If you really have to do something
with time on an FPGA you gave to care for yourself to get it there.
Moderator (Company: Titel) #5065720
LisaLLLL wrote:
> I want to get current system time with a FPGA board using VHDL
Thats a nice approach. Read a few lines about VHDL and (at least) try to
understand that your question is like "I want to build a skyscraper by
using concrete. Could you tell me how should I do?"
The answer is: "Of course concrete is necessary for a skyscraper, but
you need much more. And at first you need a plan!"
meh wrote:
> you haven't understood at all what FPGAs are and what they actually do.
Thats absolutely obviously a fact.
And after having read any book (at least the first 20 pages) and having
figured out what a FPGA is, the same thing starts with VHDL.
And finally the most important thing to figure out, is that FGPA is not
VHDL. The part of VHDL that can be synthesized on a real target FPGA is
at maximum 5% of VHDL.
But at this moment there is to see not the faintest idea about both of
them...
What HARDWARE does give you the current time? Is there a /real time
clock/  circuit on the FPGA board? What interface to the FPGA has it?
Guest #5065734
LisaLLLL wrote:
> I want to get current system time with a FPGA board using VHDL like
> YEAR/MONTH/DAY/HOUR/MINUTE/SECOND, but there is no primitive or function
> like datetime() that we can find in Python Java. Could you tell me how
> should I do?
maybe you are looking for a Time stamp passed from the Revision control
System into the VHDL-code. Maybe you shall consiter a Little script
which generates a VHDL package consisting of a constant string. See
https://stackoverflow.com/questions/18141851/compile-date-and-time-in-fpga
#5069582
Well, AS FPGAs are basically a bunch of logic circuits waiting to be
connected in any way you want it to, I'd suggest you get yourself a RTC
(Real Time Clock) module, build an interface for it and connect them
both. Then you could measure time, and after calibration also get your
time by adding the passed seconds to the calibration constant
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
