Makefile does not complete (Linux)
OP #5021883
Hi all,
I have purchased and assembled this well known component tester designed
by Markus Reschke, Markus Frejek and Karl-Heinz Kuebbeler based on an
AVR ATmega328. It is working fine, but did not came with the latest
firmware version and I would like to take advantages of the nice
improvements recently made by Markus.
I am working on Linux, have downloaded the latest firmware version from
https://github.com/svn2github/transistortester/tree/master/Software/Markus
and would like to install it on the tester.
I have configured the files to my needs but I don't why I cannot program
the ATmega328 !
The Makefile works, generates all .o .eep .hex .lss and .map files but
stops at this point, it does not generate any error, but also does not
process 'avrdude' nor the rest of the Makefile.
Here are the last lines produced by 'make -f Makefile' :
avr-gcc -mmcu=atmega328 -Wall -mcall-prologues -I. -Ibitmaps -DF_CPU=
avr-gcc -mmcu=atmega328 -Wl,-Map=ComponentTester.map main.o user.o
pau...
avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock -R .signature
Compone...
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load"
--chan...
avr-objdump -h -S ComponentTester > ComponentTester.lss
AVR Memory Usage
Device: atmega328
Program:   20554 bytes (62.7% Full)
(.text + .data + .bootloader)
Data:        207 bytes (10.1% Full)
(.data + .bss + .noinit)
EEPROM:      608 bytes (59.4% Full)
(.eeprom)
I am new to Linux, AVR, makefiles and can't find a clue to go on.
Any help will be welcome !
Thank you
Best regards
Guest #5021892
Seems to me like it works as intended. Makefiles are based on rules. If
you don't explicitly specify a rule, it will apply the first one in the
Makefile, which is 'all'. Then it recursively applys all rules that are
specified as dependancies of 'all'. This doesn't include the rules
'upload', 'dist' or 'clean', so those are not applied.
Guest #5022023
Thierry R. wrote:
> Alright, but how to specify that all rules must be applied ?
Why would you want to?
> I found no info in 'man make' !
> Do I have to modify the Makefile itself, and how ?
No. You just specify what you want to do. With a simple
make
[/C]
you generate the program. When you want to burn it onto a device, you write:
[Code]
make upload
If you want to put everything that's relevant for providing the sources
to someone into an archive, you do
make dist
And for removing anything that was generated, you do
make clean
Why would you want to do all of that every time?
Start a new thread
