Is ENTRY(_Reset) redundant here?
OP (Company: ss) #5015260
I read a code somewhere:
startup.s:
.section INTERRUPT_VECTOR, "x"
.global _Reset
_Reset:
    B Reset_Handler /* Reset */
    B.
Reset_Handler:
    LDR sp, =stack_top
test.ld:
ENTRY(_Reset)
SECTIONS
    . = 0x0;
    .text: {
    startup.o (INTERRUPT_VECTOR)
    *(.text)
I understand that ENTRY(_Reset) set the program entry point to _Reset.
Q1. What if .text does not start from 0x0? Will the first instruction to
be executed still be "B Reset_Handler"?
Q2. In the original test.ld, is ENTRY(_Reset) still necessary, or is it
redundant? Since we already set startup.o (INTERRUPT_VECTOR) to start
from 0x0 already.
#5015292
Basically the only thing ENTRY(...) does is to place the information
about this entry point into the header of your executable, provided such
thing (header) is available and can hold such information (which is the
case for ELF, for example).
This will only have any effect if you have a loader (i.e., an ELF
loader, in our case) that will use this information at runtime. In
embedded coding, more often than not you won't have such luxury, i.e.
there isn't any header since you basically convert your ELF file into a
flat binary during the flash process.
Bottom line: in most use cases, the ENTRY() statement is basically
useless for embedded development.
Start a new thread
