Use of rotary encoder in Spartan 3E
OP (Company: Uvic) #5007575
Hello everyone,
I have generated four signals/output (G1, G2, G3 and G4) using the
attached code. G1 and G2 are out of phase while G3 and G4 are out of
phase. At present, the requirement of the code is to give a variable
phase shift between G1 and G3 as shown in the attached figure. I am able
to achieve the phase shift using the code by manually changing inputs,
reprogram, load and run. But it is taking too much time for the
experiment.
Could I be able to use the rotary encoder on Spartan 3E board to change
the phase shift? If anyone can help me with the code, it would help my
project a lot.
I can provide more information as required.
Thank you
Nirav
Guest #5010962
> the phase shift?
I think: yes
You could write code which detect edges on the rotary encoder and count
up or down a counter value.
This counter value can be used in your code to set the phase shift.
Btw. what is the minimum and maximum phase shift you need?
What resolution is acceptable?
Duke
OP (Company: Uvic) #5011521
Thank you for getting back on this Duke.
Yesterday I tried to work on the code by giving a "phaseshift" integer
in the code and introduce in the output condition statement of G3 and
G4. Initially, I thought of using a potentiometer with the board but the
code worked in a funny way, G3 and G4 does not go high on the expected
count.
The phase shift shall be minimum zero degree and maximum 180 degrees
between G1 and G3. While G1 and G2 are out of phase and G3 and G4 are
out of phase. The resolution can be of 1 degree.
If you could help/direct me how to proceed with the code, it would be a
great help for me.
Thank you
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
